Vx Specialist South East? Running Problems.
23 replies to this topic
#21 Johnnyjap
Johnnyjap
  • 16 posts
Posted 11 July 2020 - 08:27 PM
Replace or dry it out?
Replacing, garage is saying a Corsa one as will fit?
#22 Johnnyjap
Johnnyjap
  • 16 posts
Posted 11 July 2020 - 08:28 PM
It's worth checking your laminova seals.  I had an issue with blowing maps and it turned out I was getting coolant on the sensor from the laminovas.  It was a very mild leak so infrequent top ups but inside the manifold was wet with about 1cm of water in the very bottom.
Thanks for the info, its still in the garage so will ask them to have a look.
#23 Johnnyjap
Johnnyjap
  • 16 posts
Posted 11 July 2020 - 08:30 PM
Probably a little late but fwiw recommend Plans. They've been handling mine for the last 10+ yrs. Great service.
Sent from my Pixel 2 using Tapatalk
Thanks, Ive read mixed review both them and BOT but I guess most garages do. The VX is not in a specialist at the mo but to be fair they have been good so far. I was a bit concerned at first where to send as its not a standard 2.2 as had the SC added.
#24 Johnnyjap
Johnnyjap
  • 16 posts
Posted 11 July 2020 - 08:32 PM
i have brand new seals and end plate gaskets in stock :)
Cheers, going to have it checked so if needed I will give you a shout. Such a handy forum Ive always sourced parts on here since owning!
