Ok, I'm Completely Lost!
yellow relay & friends
27 replies to this topic
#1 DX220
DX220
  • 326 posts
Posted 23 June 2020 - 05:02 PM
So my VXT intermittently ignores the starter button
So I go looking for this yellow relay.
In the boot on the left right?  :tumble:
Instead I find this little beauty (which has long since been dead!)
https://drive.google...T2U?usp=sharing
What the.....
#2 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 23 June 2020 - 05:29 PM
Battery backup for central locking ;)
Imagine replacement long overdue if dead
#3 DX220
DX220
  • 326 posts
Posted 23 June 2020 - 05:31 PM
So where is the famous yellow relay then?
IS this not where it should be?
#4 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 23 June 2020 - 05:40 PM
Under the black plastic cover
#5 smiley
Posted 23 June 2020 - 06:26 PM
Almost at the top of the wheelarch.
Stick your head further in.
#6 DX220
DX220
  • 326 posts
Posted 23 June 2020 - 07:26 PM
Oh wait, you mean under the other bit of black plastic?
The one in the bottom right of the 1st two pictures I posted?
#7 Ivor
Ivor
  • 2,219 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 23 June 2020 - 08:03 PM
What the.....
If it's intermittent check that the connections in the block that the relay plugs into have not been pushed back and randomly touch the relay contacts, happened to me
#8 smiley
Posted 23 June 2020 - 08:20 PM
You posted a set of poststamps, so difficult to see.
Make a picture of the complete left side of the rear clam inside, not just the spare battery box.
Here they are (probably removed from the top plastic cover)
Edited by smiley, 23 June 2020 - 08:21 PM.
#9 Paul~vxT
Paul~vxT
  • 260 posts
  • Interests:Engineering
    Restoration
    Fabrication
Posted 23 June 2020 - 08:52 PM
I had an issue with the starter button not long after I bought my vx. Turned out to be the connector on the starter button itself.
Sent from my SM-G965F using Tapatalk
#10 DX220
DX220
  • 326 posts
Posted 23 June 2020 - 09:01 PM
"" really?  :blink:
I used a google drive link because the size of the pictures were too big!!
#11 DX220
DX220
  • 326 posts
Posted 23 June 2020 - 09:02 PM
Was going for the easier one to get to first!  :D
#12 DX220
DX220
  • 326 posts
Posted 23 June 2020 - 09:15 PM
"" really?  :blink:
Think you need to double click on the 3 'poststamps' when the link 1st opens
#13 DX220
DX220
  • 326 posts
Posted 23 June 2020 - 09:18 PM
BTW has anyone ever sorted the Premium Membership thing?
Still getting an error if I try to sign up.............
#14 smiley
Posted 23 June 2020 - 09:48 PM
Downloading them helped.
Nothing tucked away in that dark corner?
#15 DX220
DX220
  • 326 posts
Posted 23 June 2020 - 09:56 PM
thumbsup
I'm obviously not trying hard enough!  :D
#16 martinroger
martinroger
  • 461 posts
Posted 23 June 2020 - 10:10 PM
From the position of the loom, check that it is not behind that battery thing too.
#17 DX220
DX220
  • 326 posts
Posted 30 June 2020 - 09:07 PM
In mine fells like they are behind the bit of black plastic bottom right in the picture above
Next dry day...........
#18 DX220
DX220
  • 326 posts
Posted 06 June 2021 - 07:17 PM
So, eventually got round to finding mine, as in the picture above.  :yeahthat:
Pinned down by that massive red fuse.
Had to, car wouldn't start.
Stupidly changed the starter button 1st  :wacko:
Turns out, yellow relay is the problem.
Plugged it out, had a look, plugged it back in; car started like never had a problem!
Patted myself on the back, put everything back in place; starter button dead!  :(
Turns out to be very sensitive to position, wriggle it a bit; starter works
So, what's everyone doing about this?
  1. Just using grey relay (exactly which one please!) and fighter pilot cover over starter button?
  2. Rewiring other relay?
  3. Any reliable replacements out there?
  4. Dreaming of the day Lotus/Proton/Geely start making these again?
  5. Any way to service my dodgy one?
  6. Other
#19 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 06 June 2021 - 08:00 PM
Seperate the black block section (they slide apart) and have a close look at terminals and wiring for corrosion etc
Some contact cleaner spray might help
While seperated plug back in and try to eliminate wiring
Ideally you want to test a known working or try you suspect one on a local friendly vx owner
I would check earth's also and voltages if you have a multi meter
#20 Ivor
Ivor
  • 2,219 posts
    and now bees
Posted 07 June 2021 - 06:38 PM
Check the terminals have not been pushed back in the block ( that the relay plugs into) this happened to me. If they have with the relay in position push the terminals onto the relay contacts from underneath the block ( the side with the wires, you can see if the terminals have been pushed back if you look at that side of the block
Edited by Ivor, 07 June 2021 - 06:38 PM.
