Seperate the black block section (they slide apart) and have a close look at terminals and wiring for corrosion etc
Some contact cleaner spray might help
While seperated plug back in and try to eliminate wiring
Ideally you want to test a known working or try you suspect one on a local friendly vx owner
I would check earth's also and voltages if you have a multi meter
Check the terminals have not been pushed back in the block ( that the relay plugs into) this happened to me. If they have with the relay in position push the terminals onto the relay contacts from underneath the block ( the side with the wires, you can see if the terminals have been pushed back if you look at that side of the block
So you are both suggesting the problem may well be where the relay goes rather than the relay itself?
Hmm wasn't expecting that one.
I have a plan then; learn some more electrics!
Thanks fellas
And any of the grey relays will do for 'get me home' or a particular one of the three?
Now I've got the belt I just want to pack a set of braces as well!
