Clutches - Sc.
14 replies to this topic
#1 JG
JG
  • 13,609 posts
Posted 22 July 2020 - 11:03 AM
Getting that little chip you get sometimes as a warning that it might be coming to an end. It's original. 58k miles.
What do i need to buy?
-Clutch plate and cover
-Servo thingy
-Lightened flywheel
What is the C20LET thing all about? what compatibility? If its the same as a Saab 2.0 then i'm out.
Just buy it all from CS?
Help please :)
#2 smiley
  • 10,410 posts
Posted 22 July 2020 - 11:46 AM
If you like the current behaviour, would suggest to skip the Lightended flywheel.
#3 siztenboots
  • 26,608 posts
Posted 22 July 2020 - 11:56 AM
whichever joe / chris will supply and fit
#4 JG
JG
  • 13,609 posts
Posted 22 July 2020 - 12:28 PM
I'd like it to rev a bit more quickly.
#5 Rosssco
Rosssco
  • 4,180 posts
Posted 22 July 2020 - 12:37 PM
-Servo thingy
-Lightened flywheel
Help please :)
-Clutch plate and cover - C20LET clutch. Cheaper, holds more torque, and has the same feel as the OEM clutch. Fits the standard flywheel
-Servo thingy - Clutch slave cylinder / release bearing. Make sure you go for a good quality one
-Lightened flywheel - If you want.. TTV or something. Just don't go too light (sub 5kg) and there are no real downsides
Chris or Joe for supply?
#6 smiley
  • 10,410 posts
Posted 22 July 2020 - 12:42 PM
That it will certainly do.
#7 JG
JG
  • 13,609 posts
Posted 22 July 2020 - 02:47 PM
what are the downsides?
#8 smiley
  • 10,410 posts
Posted 22 July 2020 - 02:52 PM
My gearbox was singing afterwards for about half a year.
I guess not 100% balanced or something. It went away on it's own.
It also takes getting used to on pedal feel.
#9 The Batman
  • 30,264 posts
Posted 22 July 2020 - 05:24 PM
i got clutch and fast road clutch and slave in stock bud
#10 chris_uk
  • 10,060 posts
Posted 22 July 2020 - 08:42 PM
i do the c20let 4x4 clutch kit for which is good for anything a M62 charged car can throw at it, i've also got Gm, sacks & luk slaves all in stock.
ttv flywheels in stock too should you want one.
#11 sford
sford
  • 1,431 posts
Posted 23 July 2020 - 07:56 AM
I put a lightened flywheel on mine just before SC'ing and I don't think it made a huge difference to the feel of clutch engagement/use. It rev's more freely but not to the point it is unusable. My wife is still happy to drive it and she is the first to voice distaste for something if it's slightly more effort! Other than that, the slave cylinder (definitely replace this) and clutch can be kept oem. The 'uprated' one from CS is just a slightly better clutch from another model (guessing the C20LET 4x4 ). I had little trouble when fitting mine to the point I'd say it was fairly easy but time consuming. It was quite a nice project to do as there were various stages to take apart/refresh/renew and we all know you love a bit of project creep.
#12 vocky
Posted 23 July 2020 - 03:39 PM
Sachs clutches are very good, so are the TTV lightened flywheels
#13 oakmere
oakmere
  • 2,142 posts
Posted 23 July 2020 - 07:28 PM
I think Elise parts sell the slightly heavier lightweight flywheel šŸ˜†.
Might be a better option for the road.
#14 pete-r
pete-r
  • 2,771 posts
Posted 24 July 2020 - 12:19 AM
I’m getting the light flywheel and 4x4 clutch fitted shortly if you want to try it when you are in Swansea next
#15 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 25 July 2020 - 09:35 AM
Dont buy a Courtenay uprated one. Mine exploded after just a 1000 miles on a straight so wasnt even using it at that time!
