Z22Se 58Mm (Std) And 68Mm Throttle Body Comparison And Weight Loss
#21
Posted 25 October 2020 - 12:13 PM
I remember - I was one of them.
And, I agree the 52mm 'upgrade' made it worse on cars without re-calibration. The MEMS1.9 and 2J were awkward to re-work.
You can read about my adventures with all manner of MG Rover k-series here: here: https://www.mg-rover.../search/112994/
I wrote tons about them and still get an email inbox full of them every month.
I even made a 50mm throttle body once - https://www.mg-rover...1/#post-5053582
I still build k-series. It's a good engine, but even I can't deny it had its troubles in early production, and the dealer and customer service denials just made it look worse.
It makes a great teaching case study, and lots of engines that came after it took lessons from it.
#22
Posted 25 October 2020 - 02:51 PM
Yeah.. The Rover K is a classic example IMHO of an engine that suffered the most damage from bad manufacturing tolerances and cover-up or denial reaction from the manufacturer and not so much a basic problem in the engine itself.
It's design was quite clever, new and light, but it's just that cost-cutting measures (plastic dowels.. sigh..) and inconsistent production efforts (esp. varying liner heights) combined with less than stellar finishing of parts was something this fairly revolutionary 'sandwich' design with the long bolts just could not tolerate and the results are well known with blowing headgaskets..
Combine that with pushing the limits of the engine envelope as it grew from it's original 1.1 to a 1.8 in the same block and it was unfortunately a disaster waiting to happen.
The choice of a heat-sensitive/annealing aluminium alloy for the head was also not that great combined with the original thermostat setup.
These days, most K's (re)built properly and with attention to the various parts, are quite reliable even to pretty high power levels. Pity Rover never managed that.. (and now the N-series parts supply like headgaskets seems to be suffering from counterfeits in the official parts delivered from the new chinese owners..)
#23
Posted 28 October 2020 - 03:04 PM
The 65mm le5 is wider then the 58mm oem tb.
This is an issue when using the saab intake manifold en tmap. 65mm tb gets in the way of the tmap.
But thats more for the turbo guys I guess.
Leaves me with a 65mm tb...
#24
Posted 28 October 2020 - 04:05 PM
That is plenty to drive it around the church like you do.
#25
Posted 29 October 2020 - 12:35 AM
#26
Posted 04 November 2020 - 01:30 PM
CS we’re seeing approximately 5-7 bhp gain from the 65mm TB on a CS5 level of tune. They could never get the mapping right though at low load giving the EML issue.
#27
Posted 09 November 2020 - 07:08 PM
I don't know what a CourtneySport5 level of tune implies but, and I don't want to besmirch them here, it sounds like they changed something and didn't compensate for it (or a related thing) elsewhere.
If that was the case then I can sympathise - reading the tables in the GMPT15 is a pain. It's taken me ages just to get to the point where I can remove the EGR, change the idle and warmup curve - that dual range coolant sensor calibration was a pain - and adjust the fuel tables.
#28
Posted 13 November 2020 - 12:59 PM
Klansen did the mapping work for CS but could never fully crack the ECU.
