Removal Of Control Valve, Fuel Evaporator
5 replies to this topic
#1 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 19 April 2005 - 08:36 AM
Has anyone removed the load of pipework around the filler neck? Its for the fuel evaporator and control valve. Thinking of it but not sure what will happen regarding the ecu. Theres a vacum pipe and a sensor.
#2 Ricky2772
Ricky2772
  • 3,685 posts
  • Interests:For those who grasp for Hir beyond the horizon of usual consciousness, preparing for the time when something powerful will present Hir-Self This advise is given...
Posted 19 April 2005 - 11:11 AM
I removed everything, left only the sensor and that little plastic thing it attaches on... mind you, I have an ally elise tank, with only 2 hoses to the intake fuel, and not 4. car is running ok. I had to add a one-way valve to allow air to compensate for fuel being used inside tank....before that, being air-tight, it created a vacuum that shrunk the tank walls!! :blink:
#3 2-20
2-20
  • 1,317 posts
Posted 19 April 2005 - 06:40 PM
FMI how much does an Elise tank cost ?? Thanks
#4 Pidgeon
Pidgeon
  • 5,254 posts
Posted 20 April 2005 - 06:45 AM
Is completion in sight yet?
#5 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 20 April 2005 - 03:01 PM
Ricky, where did you one way valve fit ? Was it on the overflow pipe that connects right at the top of the fuel filler pipe? Paul
#6 Ricky2772
Ricky2772
  • 3,685 posts
Posted 20 April 2005 - 07:31 PM
Thanks
check elise-parts.... same tank as MK2.
