16" X 6.5j Front Wheel
#21
Posted 18 November 2006 - 04:11 PM
#22
Posted 18 November 2006 - 04:46 PM
#23
Posted 18 November 2006 - 05:32 PM
#24
Posted 18 November 2006 - 08:37 PM
#25
Posted 18 November 2006 - 08:41 PM
#26
Posted 19 November 2006 - 10:09 AM
#27
Posted 19 November 2006 - 11:27 AM
#28
Posted 19 November 2006 - 11:48 AM
Now comes the hard part, the cost!
I bought 1 VX220 rear and it cost £295 these wont be cheap will they!
#29
Posted 19 November 2006 - 12:00 PM
#30
Posted 19 November 2006 - 12:08 PM
That really is awful! Why did I even post that!
Edited by danyeates, 19 November 2006 - 12:08 PM.
#31
Posted 19 November 2006 - 03:12 PM
Pathetic half arsed attempt at what it would look like with low profile tyres!
#32
Posted 19 November 2006 - 03:19 PM
anyone want to go halves?
http://cgi.ebay.co.u...1QQcmdZViewItem
suppose the only downside is the spokes are curvy so look a bit like venoms! ha
anyone for a dimaond cut spoke face to make it match the rears better?
Edited by Guy182, 19 November 2006 - 03:23 PM.
#33
Posted 19 November 2006 - 03:31 PM
Don't know if the 6.5 rim would be enough, but a 225/50-15 would also match the standard rear diameter, if you wanted to run a full set of 16s for whatever reason. I've seen this on at least one track car, and it looked fine, plus potentially cuts rotating mass. Wheel offset (ET) may be way off, though.
These may also be the perfect way to put more appropriate rubber on for places with colder winters...
Edited by Ferguson, 19 November 2006 - 03:44 PM.
#34
Posted 19 November 2006 - 03:38 PM
Just a note, the standard Astra tire size (also shown in the pics) is 205/55-16. These are too tall. 195/55-16 is a perfect match to the standard fronts, and there is a large selection of performance tires in this size.
if i get a pair of the 16x6.5's the plan is to get another pair of standard vxt rears and then fit the r888 as per the usual vxr/elise sizes. just for track use and a bit of summer use.
and keep set of full standard vxt wheels/tires for normal use.
hope that clears the offset/tyre size points up
#35
Posted 19 November 2006 - 03:46 PM
That was clear. Just opening up discussion of other options. I still wonder if a 195/55 instead of 195/50 may cure some of the ABS problems people have when switching to 16/17.
#36
Posted 19 November 2006 - 06:30 PM
#37
Posted 26 November 2006 - 01:03 PM
#38
Posted 26 November 2006 - 02:58 PM
#39
Posted 26 November 2006 - 08:16 PM
#40
Posted 27 November 2006 - 12:42 PM
They are some nasty wheels
