Increasing The Rpm
56 replies to this topic
#1 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 November 2006 - 10:08 PM
What would the max RPM for the following configuration:
  • Ported and gas flowed cylinder head
  • Titanium valves or Ferrea special alloy valves
  • Ferrea dual coil valve springs + Titanium Retainers
  • Decent set of cams
  • WiseCo pistons - Rated for forced induction
  • Eagle connecting rods
  • GM steel billet performance crankshaft with bearings to match
Basically I want to increase the RPM beyond the 7000 threshold. What do I need to hit 10000-12000?
At high RPM will the standard oil pressure be enough?
:D
Edited by speedster, 11 November 2006 - 10:41 PM.
#2 almar
almar
  • 254 posts
Posted 11 November 2006 - 11:11 PM
if you need the speed buy a pagani zonda :beat:
#3 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 November 2006 - 11:29 PM
Well I don't really need speed, I am just interested in modifying the car and increasing the RPM threshold is one mod I want to work on! Hope that makes sense :)
#4 coopa
coopa
  • 952 posts
  • Interests:The usual
Posted 11 November 2006 - 11:45 PM
B) What about an inlet manifold more tuned to high end power? Decent plenum and shorter runners etc. Higher flow throttle body/bodies? Cooling system?
#5 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 11 November 2006 - 11:55 PM
B)
Cooling system?
My first shot is to modify my dbilas intake by adding additional injectors onto it's runners. I picked up up a VXR fuel rail + Injectors (cheers griffo) and have injector pockets on the way. I have a 68mm TB attached and it works a treat! Will wait to see how it performs with head and block work.
Cooling should be good but I will probably add an oil cooler.
Long term I'd like to build something that's high revvvving... :saw: so want to get the spec right.
:D
Edited by speedster, 11 November 2006 - 11:58 PM.
#6 vocky
Posted 12 November 2006 - 10:30 AM
Dude's bottom end 'left the building' at about 8800rpm :beat: so reaching 10k rpm is not going to be easy the balancer shafts will need removing and the water pump swapping for electric, then all the oil ways blocking off which used to feed the bearings for the balancer shafts with the mods you're looking at, 9k rpm could be the max I've got a spare bottom end which I'm thinking of doing something similar with, but keeping the standard crank, maybe low compression pistons and then a sc, or then again I might just sell it and get a 2.4 vvt engine from the states ;)
Edited by vocky, 12 November 2006 - 10:31 AM.
#7 dude
dude
  • 1,404 posts
Posted 12 November 2006 - 10:40 AM
Well my bottomend went at 8157rpm. You will never reach 10000rpm with 94,6mm in stroke. The pistonspeed will exceed laws of physics. If you go with a 86mm stroke it´s possible but not easy. Expect 500-800km between restoration.
#8 vocky
Posted 12 November 2006 - 10:44 AM
thanks for the correction Dude :)
I knew you got over 8k and it went bang :P
so using the 2.0 turbo or sc bottom end could get a higher rpm
Edited by vocky, 12 November 2006 - 10:45 AM.
#9 VIX
VIX
  • 9,497 posts
Posted 12 November 2006 - 10:49 AM
Any information here? -
http://www.gm.com/co..._build_book.pdf
chinky chinky
PS Hope this is the right engine! :unsure:
#10 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 12 November 2006 - 11:12 AM
chinky chinky
That's an interesting read, 75bhp NOS eh? could be a fairly cheap and 'relatively' simple option :)
Apparently you have to make sure you use 92 octane fuel after performing any of the mods tho :rolleyes:
#11 coopa
coopa
  • 952 posts
Posted 12 November 2006 - 11:41 AM
That's MON not RON thumbsup
#12 mandarinvx
mandarinvx
  • 12,621 posts
Posted 12 November 2006 - 01:38 PM
Ah, thought it was a bit odd! So what does it mean? is 92 MON equiv to our 98 RON :blink:
#13 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 12 November 2006 - 11:15 PM
8k ain't a bad start :D The kit I'm looking at is GM Performance parts, the weakest of which is rated for 650HP. Building from the bottom up - Junking the standard block and going for the Ecotec race cylinder block, billet steel crankshaft, billet connecting rods terminating with either the WiseCo pistons or GM Performance pistons then adding a machined cylinder head with max port sizing and as much titanium in the head as possible!! I agree vocky, dumping the water pump for electric, good option thumbsup
#14 JG
JG
  • 13,617 posts
Posted 13 November 2006 - 11:09 AM
small bore - long stroke, torquey engines that do not lend themselves to high rpm large bore - short stroke, no torque but can be tuned for power at high rpm. Motorcicle engine. Vx 2.2 is a very long stoke - very small bore. it is never going to like high rpm.
#15 vocky
Posted 13 November 2006 - 11:29 AM
Dude came up with that idea Imnotworthy
I'm rebuilding a bottom end at the minute, the balancer shafts have got to go - I can't believe the weight
not sure whether to keep the chain driven pump or swap to electric
Edited by vocky, 13 November 2006 - 11:29 AM.
#16 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 13 November 2006 - 06:57 PM
I been looking at the GM Race Cylinder block. It's spec's (in inches) are:
  • Fully-machined aluminum block
  • 3.400" bores
  • 8.700" deck height
  • Steel liners machined for stainless steel O-rings and head gasket
Can you calculate the stroke via the deck height? How does that compare with a standard NA block? (The bore is the same).
What's the weight saving gain?
Edited by speedster, 13 November 2006 - 07:03 PM.
#17 vocky
Posted 13 November 2006 - 08:01 PM
would there be any ?
I was just thinking that the water pump chain could be removed, so less drag on the crank
I will probably keep the driven pump, mainly due to reliability concerns
from what the gm build book states, the standard block is good for 400bhp
the only items I'm going to upgrade are the conrods, by fitting eagle units and also fit head studs
Edited by vocky, 13 November 2006 - 08:13 PM.
#18 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 13 November 2006 - 08:41 PM
If you physically remove the pump and get a light weight electrical unit you could save a kg or two. Not sure what the weight of the pump+chain is so best get figures and do some maths :P
Yeah, the standard block is good for 400hp but I'd like to start a serious build with the race block. If I ever decide to add a FI kit I would plan on bringing the plant up into the 500's.
Dude, what gearbox is the FI Badster running with and what drive shafts are attached? If I want a gearbox that can handle up to 600hp am I looking at a custom job?
Vroom vroom!!
:D
Edited by speedster, 13 November 2006 - 08:44 PM.
#19 vocky
Posted 13 November 2006 - 09:08 PM
8.700" deck height
just measured standard block, about 222mm, so 8.7" thumbsup
500 bhp :o have you been talking to cp or dude :D
Edited by vocky, 13 November 2006 - 09:11 PM.
#20 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 13 November 2006 - 09:40 PM
8.700" deck height
thumbsup thats means we're can't get away from a long stroke motor. Wonder how GM got their import fighter up to and beyond 10,000 RPM?
:lol: I want to make sure I'm working on something that is powerful and reliable... what are CP and Dude up too :rolleyes:
