Posted 21 November 2006 - 10:40 PM
Posted 21 November 2006 - 10:41 PM
Posted 29 August 2008 - 07:49 AM
Posted 29 August 2008 - 08:50 AM
why don't we get threads like this anymore ?
Posted 29 August 2008 - 08:58 AM
Posted 29 August 2008 - 09:01 AM
because they get posted on www.z22se.co.uk instead![]()
I'm currently building a 11:1 CR bottom end with wiseco special order pistons and also building up a saab head with gm racing components.
I'm aiming for a reliable 7600 rpm top end, rather than my current 7000rpm, so hopefully another jump in power.
Posted 29 August 2008 - 01:43 PM
Posted 29 August 2008 - 01:52 PM
Posted 29 August 2008 - 02:06 PM
Posted 29 August 2008 - 03:15 PM
And then what happened ....My LY used to change at around 7000+ rpm
Posted 29 August 2008 - 03:29 PM
Posted 29 August 2008 - 03:55 PM
i did think when i posted that i would get a similar response fair play
Posted 29 August 2008 - 05:18 PM
so for the z20let with its 86 mm bore and stroke and 9.5:1 compression, where is the limit , crank or rods ?
Posted 29 August 2008 - 09:59 PM
Posted 30 August 2008 - 07:52 AM
I plan to build from the oil pan up! I've a budget of around 12k for the the engine build. I will bring the engine up to it's safe max RPM and be content with that, main focus is torque and power. Going with GM Billet crank plus their Ecotec Racing Piston & Pin Set (Part # 889586350) or similar gives you an engine with 2.0 liters of displacement with 10.5:1 compression so I should be able to move beyond 8000 RPM safely. Again, I'm looking for power + long term reliability. The dry sump concept is interesting.........
Posted 30 August 2008 - 10:53 AM
I am surprised static, dynamic balancing and blueprinting gets so little mention in this thread. If this is a given then I will sound like a someone giving lessons in egg sucking to their elders and betters so please accept sincere apologies for that.
I don't think I need to explain what this is about to you guys but it must be crucial to reliable max revs and power.
