Posted 19 April 2007 - 06:30 PM
Posted 19 April 2007 - 07:22 PM
Posted 19 April 2007 - 08:02 PM
I'm currently looking at doing a TB conversion using the standard ECU and some GSXR TBs. My plan is to cut up an ETB and jam it onto the separate TBs to control opening. Next weekend i'm off to use a CNC milling machine at a friend's work to cut out a manifold, and then we'll see if it works or just totally throws the ECU
While I get Arno's point about measuring vacuum, i'm hoping it'll work out ok if there's a suitably restricted pressure change supplied to the sensor. My kit car has been running with separate carbs for years, with a vac feed going into an ECU that controls timing. I've never had a problem, but then the Z22SE's ECU is a lot more complex.
Still, it can be debated for ages, but the only real way to know for sure is to try it and find out
Looking at the ETB it doesn't go from fully flat to fully open - its a strange shape that makes it look like it might only move 60 degrees from fully closed to fully open. Is this the case? If so, i'm going to need some crazy lever arrangement to translate that to a proper 90 degrees movement.
Posted 20 April 2007 - 02:45 PM
I'm hoping not... In the TBs a vacuum feed is taken off each barrel via a pretty small hole and then mixed, so i'm hoping the violent pressure changes will be evened out. The pressure changes might even be evened out too much!! I'm going to make a small reserviour though with an adjustable aperture so hopefully I can tweak it.With iTB's won't the MAP signal behaviour be quite different than the standard manifold?
If you have independent engine management it almost certainly would be easier to use a cable. As soon as you go down that route it gets expensive though (hacking up wiring looms, the ECU itself, etc...). This is really only for a bit of fun (and because no-one has done it before - prob for good reasonBe interested in seeing how you manage with the ETB control +iTB setup. I reckon a seperate floor mounted throttle pedal plus cable be alot easier though....
Posted 20 April 2007 - 03:21 PM
I'm hoping not... In the TBs a vacuum feed is taken off each barrel via a pretty small hole and then mixed, so i'm hoping the violent pressure changes will be evened out. The pressure changes might even be evened out too much!! I'm going to make a small The though with an adjustable aperture so hopefully I can tweak it.
). All in its going to cost me less than £200 and its all fully reversible, so I reckon its worth a try even if it backfires totally.
Posted 20 April 2007 - 08:44 PM
Went and had a chat with Mr Dave at Mountune, hes a legend in my books. He showed me some roller barrel TB's that are used on the WRC focus. a snip at £1000 (come with 4 port matched carbon trumpets, and TPS)lol, but damn good. He did suggest that for road use that butterfly TB's would be best. They have some 40mm TB's that flow the same as Jenvey 45mm items due to jenvey using a girder for the throttle spindle and the mountune ones using a near flat/invisible butterfly.
I only want a nice easy 200bhp and they will try to work out a good option for that route. but its not gonna be "that" cheap for mountune components but they will be far superior to the jenvey/webcon items.
Posted 20 April 2007 - 11:13 PM
Posted 22 April 2007 - 03:17 AM
Posted 23 April 2007 - 12:06 AM
they look good. where did you get them from? or is it hush hush lol
Posted 24 April 2007 - 02:54 PM
I was planing to build a slave throttle drive motor unit mounted to the bulk head with a shot cable linking to the TB's. I rekon the standard TB has a stepper motor and a feed back pot inside so planed to have the a stepper motor driving the cable with the feedback pot mounted on the TB's for safety(incase of cable failure)
Posted 24 April 2007 - 04:34 PM
I'm not sure if you've fiddled with your TB yet, but it feels a lot like the TB is actuated by a geared motor acting against a spring (not a stepper!). It would probably be reasonably easy to rig something up...
Well, i'm off this weekend to try and mill myself out a manifold for the TBs, so i'll try and let you know how it goes
