Lambda Sensor Replacement Guide NA
33 replies to this topic
#21 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 10 August 2009 - 07:28 AM
I wouldn't use the universal ones again. The problem is that although all sensors are basically the same, the universal ones are of a lower quality and tend to fail a lot easier.
If you can get a high quality universal one, then that would be fine..
Same here
#22 Anarchy
Anarchy
  • 2,237 posts
Posted 29 August 2009 - 01:30 PM
Fitted a cheap Ebay one, EML went out after a few miles, hope it lasts.
#23 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 21 December 2009 - 06:07 PM
Excellent guide thumbsup. Worthy of a bump which makes it easier for me to find when my new lambda sensor arrives.
#24 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 22 September 2010 - 10:06 PM
I agree that this is a great guide... But a tip from me is to check the cable on the sensor before ordering a replacement. You can do this by stripping a tiny amount of each of the four wires (near the actual sensor) and then using a multimeter to test whether each cable is effective by touching one end on the bared wire and the other trying to find the connector pin on the socket that connects to the wiring harness. I found a break in one on my rear sensor and saved the hassle of trying to remove the sensor (which on my 8yr old car was looking like it would have required removing the back box). I then felt the particular wire along it's length and found a 'flattened' section, bared the wire and crimped the cable together. Three weeks on and so far so good.
Edited by Mangham54, 22 September 2010 - 10:06 PM.
#25 welshwhiz
welshwhiz
  • 57 posts
Posted 25 November 2010 - 02:55 PM
HI guys, probably going to replace both sensors. I haven't really had a good look yet at how to change, but does the udner tray of the car need to come off, if so is it a big job, and does it need to be jacked up? Thanks.
#26 welshwhiz
welshwhiz
  • 57 posts
Posted 27 November 2010 - 10:36 AM
You don't say where the rear sensor connection is? Please help.
#27 Paulus H
Paulus H
  • 2,063 posts
Posted 01 January 2011 - 04:06 PM
Just be wary tho'. You might be getting error codes because the connector on the end of your lambda sensor is kaput. If that is the case the universal lambda is no use. Recently I bought a non branded (but with Vaux connector) position 2 lambda sensor. It lasted 10 miles, basically the connector was really poor quality and would not connect consistently. I should have a replacement waiting at the dealer now. The position 1 sensor I bought at the same time was branded, I think it was NGK. This worked fine. Paul
#28 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 30 May 2013 - 11:08 AM
Good guide...
Is the NA  Vs Tubby sensor the same (running a tullet 3")
Thanks
#29 SteveA
SteveA
  • 9,159 posts
Posted 31 May 2013 - 09:34 AM
The turbo sensor has a different loom plug to the one on the N/A, not sure about the actual sensor though.
#30 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 11 July 2013 - 03:14 PM
Does anyone know a part number that is not vx related but is the same part?
I need a sensor and i have a £40 vaux voucher, so I may as well use it :)
#31 hainesy
hainesy
  • 239 posts
  • Interests:Proud to be the sensible majority shareholder of the Northants Pedantic Crew
Posted 12 July 2013 - 11:19 PM
I had a quote from Vauxhall last week for a new one and it was just over £140, voucher would have made it £100, ordered one from autovaux for £77 delivered so still have voucher.
Part number for rear on autovaux is AS12567680
#32 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 13 July 2013 - 09:08 AM
I had a quote from Vauxhall last week for a new one and it was just over £140, voucher would have made it £100, ordered one from autovaux for £77 delivered so still have voucher.   Part number for rear on autovaux is AS12567680
#33 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 25 July 2013 - 03:18 PM
recieved :)
I was kind execting autovaux to provide an OEM one... I wonder where this Lemforder one comes from and if I have been ripped off for what I could have bought cheaper elsewhere? :rolleyes:
#34 TheOneTrueAnt
TheOneTrueAnt
  • 26 posts
Posted 21 July 2014 - 12:10 PM
Just tackled this one at the weekend, went... ok... the old sensor was well and truly seized in there. I even resorted to breaking the body of the sensor off so I could get a socket on it with an extension bar and even then with my full (not inconsiderable) weight on it the thing wouldn't budge!!!
Thankfully found this video though:  which saved my bacon; basically run the car for 10 minutes to let things warm up and then the thing came right out. Being doused with a ton of WD40 may have helped too.
Then a good half-hour's work with a thread chaser (Laser Tools 3465 http://www.amazon.co...uct/B003AN1D3C/ ) and the new one went in without too much trouble.
