Bubbling Paintwork.. Vauxhall's Response..
#21
Posted 07 April 2008 - 11:49 PM
#22
Posted 27 April 2008 - 07:26 PM
#23
Posted 27 April 2008 - 07:33 PM
Edited by james141, 27 April 2008 - 07:36 PM.
#24
Posted 27 April 2008 - 08:39 PM
#25
Posted 27 April 2008 - 08:47 PM
Now going to forward all the correspondance to the SMMT and see what they have to say..
Also contact the RMIF Conciliation And Arbitration service
http://www.rmif.co.u...umers.aspx?id=0
#26
Posted 27 April 2008 - 09:15 PM
Strugs, how old is your car? And whos has actually inspected it?
I take it you booked it into your local dealer, area warranty assessor inspected and refused the claim. You then wrote to Vxl and they still denied?
Have your car met the warranty requirements for a claim? eg, still within 6yrs old, fsh?
It really is crap service from Vxl and certainly makes you think twice about buying another one!!
When i had my work done (replacement clams, door), the local garage couldnt of been more helpful. Shocking to see how much it can vary from region to region
The car's a 2003 NA with fsh but the issue is that Vauxhall are saying the osmosis is covered by the paintwork warranty (which has expired) and not the anti-perforation warranty. It was inspected by the Customer Care District Manager..
#27
Posted 27 April 2008 - 09:20 PM
Thanks for that Cheeky. Reading that site, they seem to imply they would be more relevent than the SMMT?
#28
Posted 27 April 2008 - 09:49 PM
#29
Posted 27 April 2008 - 09:57 PM
With the name 'Parfitt' I'm not surprised he wanted to maintain the Status Quo.Ok, Ive just been through my correspondence with Vxl and one of the letters states that the replacement of "the rear clam shell and door under the anti-perforation warranty."
This letter was typed on behalf of C W Parfitt, MD and Chris Allen, Customer District Care Manager.
I trust that in the end Vxl will eventually back down, just a matter of pressure.
If you require any more info just let me know
#30
Posted 27 April 2008 - 10:00 PM
#31
Posted 27 April 2008 - 10:06 PM
i used to work in their IT dept in rugby - their head of conciliation (stuart?) advised me on lack of parts (eg VXR wheels). Very helpful and lots of experience
#32
Posted 27 April 2008 - 10:12 PM
Edited by lizvx220, 27 April 2008 - 10:19 PM.
#33
Posted 27 April 2008 - 10:15 PM
6) They say that as the bubbling was visible at the time of purchase, I should have paid a price reflective of the condition;
I just thought i'd mention this in here, as the issue came up on a booze up with me mates [one of whom is a fibreglasser/ sprayer]
Unless the contaminated material is completely removed - repairing such defects ie - a re-spray [or acid treatment like liz said] will only hide the problem short term - Osmosis will re-occur within 18mnths to 3yrs [sometimes quicker] He's worked on a few elises that must have once had 'bad' touch up work on stone chips, later leaving them with bubbling - he went on to say the only real way to repair is to replace.
No wonder vauxhall are refusing to do it.
Edited by Richy, 27 April 2008 - 10:18 PM.
#34
Posted 27 April 2008 - 10:28 PM
Expect a PM!
#35
Posted 27 April 2008 - 10:29 PM
Unless the contaminated material is completely removed - repairing such defects ie - a re-spray [or acid treatment like liz said] will only hide the problem short term - Osmosis will re-occur within 18mnths to 3yrs [sometimes quicker] He's worked on a few elises that must have once had 'bad' touch up work on stone chips, later leaving them with bubbling - he went on to say the only real way to repair is to replace.![]()
#36
Nice one, thank you..
#37
Posted 27 April 2008 - 10:31 PM
I was reading about the paint problem with interest ,as I noticed the same bubbles in my rear clam,which is on a 54 turbo just in front of the rear spoiler we have also 2 other vx a 04 turbo and a 2.2 n/a (greedy I know) none of these cars have the bubbles ,when I first saw it I thought that looks like osmo as I have been a boater for 30 years.and have seen many different types of it ,this type appears to be what I would call nettle rash.
On mine ,it has small blisters, I have seen cases on boats where there have been egg sized bubbles ,and delamination of the fibreglass has occoured ,in boats this has been associated with areas of uncured resin within the matting,which when submerged in water turns into an acidic type fluid in the blister,which due to its density is drawn towards the outside of the hull,and creates the bleb in the gelcoat,
the remedy with boats is to burst them ,wash out the acidic fluid and fill them with a epoxy two pack,or to leave them ,however on our cars it is not acceptable to have these blisters showing,Having owned S1 and S2 I have not seen this in any Lotus,but the S1 is a thicker layup ,in some makes of boat it was put down to certain factorys not leaving heat on in the factory at night ,and so some resin remained uncured,and it was laid up by hand ,modern fiberglass tends to be a chopped sprayed on layer ,and should be far less likley to suffer ,so it is a strange one,in boats this would usually effect a boat that is 10 years old ,and bear in mind submerged for 10 months of the year,in a boat you would put it down to the manufacturing process .
Thanks for this Liz - a lot of the basic research I've done on this kind of problem has been related to the marine industry..
#38
Posted 27 April 2008 - 10:35 PM
..he went on to say the only real way to repair is to replace.
Exactly what Vauxhall allude to in their letter.. If this doen't come off, I'll be hoping that Munchers replacement clam idea ends up working out!
#39
Posted 28 April 2008 - 12:11 AM
Expect a PM!
Il reply to your PM Monday afternoon,
#40
Posted 28 April 2008 - 06:12 AM
Well mines currently at luton getting the clams done, and mine is a June 2002 car, and i bought it in december 2007, so technically if they have a problem with your car, then they should have had a problem with mine, but mine sailed through the inspection, has been away 2 weeks now and im missing her!
