My Diy Supercharger Build
43 replies to this topic
#1 rik
rik
  • 2,187 posts
Posted 30 November 2008 - 05:33 PM
Hi. Here's a brief run down of the supercharger build I did. Full details can be found on the z22se.co.uk forums
Some things arrived from USA ebay..
broken during transit... need a new one
#2 rik
rik
  • 2,187 posts
Posted 30 November 2008 - 05:35 PM
More stuff..
Charge cooler radiator
Water pump
Painted
Dual pass end plate for added cooling (from zzperformance.com)
Fitting
Modified 100amp alternator (the method we used to fit the 120 with the 2.4).. very little clearence still!
SC on just for show.. main water pipe needs extending
horrible holes that need to be made to push the cc rad pipes to.. one low to push them through (I attached the tube to copper pipe and shoved it through) needs some tidying up with a file and something to line the hole so it doesnt wear through the hoses
and one high up for them to come out of (you need to get your hand inside the sill from the cabin)
#3 rik
rik
  • 2,187 posts
Posted 30 November 2008 - 05:36 PM
through the radiator housing
Fuel pipes need moving and water pipe needs extending
Header tank for charge cooler
Plumbing.. what a mess
Alignment bungs from courtenays (LSJ head must have M8 holes.. we have M6, so these make sure it's centered)
Idler pulley from courtenays
#4 rik
rik
  • 2,187 posts
Posted 30 November 2008 - 05:37 PM
It bolts onto the outside bolts of the alternator (longer bolts supplied by courtenays)
Injectors changed to Z20LET type (bosch type connectors)
Wiring..
Fuel pipes/belt on
ECU and air filter
Almost done
#5 rik
rik
  • 2,187 posts
Done
#6 Jameshs
Jameshs
  • 3,511 posts
Posted 30 November 2008 - 05:39 PM
So far so good. How much did it cost and what does it run like?
Edited by Jameshs, 30 November 2008 - 05:40 PM.
#7 Baron Von Scubadaddy
  • 6,645 posts
Posted 30 November 2008 - 05:44 PM
Oh my god that looks amazing top work there Imnotworthy I bet it's gonna be soooooo fast
#8 VIX
VIX
  • 9,497 posts
Posted 30 November 2008 - 05:53 PM
:yeahthat: Top work! thumbsup
#9 MaDFreeBiRD
MaDFreeBiRD
    VX gone :( 350Z replacement :D
  • 3,385 posts
Posted 30 November 2008 - 05:58 PM
good stuff that man! thumbsup I too would be VERY interest to know the details :D
#10 rik
rik
  • 2,187 posts
Posted 30 November 2008 - 05:59 PM
haven't taken it for a run yet.. i'd love to but these icy roads are definately not the place to do it The engine started first time and runs really nicely
#11 southpaw
southpaw
    sans vx for now
  • 2,462 posts
Posted 30 November 2008 - 06:08 PM
Imnotworthy good stuff thumbsup
#12 vocky
Posted 30 November 2008 - 07:08 PM
well done Imnotworthy
#13 Muncher
Muncher
  • 4,494 posts
Posted 30 November 2008 - 07:21 PM
Itching to get mine together now :( Have all relocated the ECU, done all the wiring, swapped back to standard cams, had the rocker cover powdercoated, just waiting for the actual supercharger and manifold from Courtenay! Next couple of days hopefully! I've even got the blower cams, rods and Harrop supercharger already for the stage 3... :P
#14 Jameshs
Jameshs
  • 3,511 posts
Posted 01 December 2008 - 08:30 AM
What does stage 3 give you?
#15 rik
rik
  • 2,187 posts
Posted 01 December 2008 - 08:40 AM
Over 300bhp we're hoping
#16 Jameshs
Jameshs
  • 3,511 posts
Posted 01 December 2008 - 10:37 AM
Any chance you could give me a price breakdown of what this conversion cost?
#17 siztenboots
Posted 01 December 2008 - 10:40 AM
not on original internals , or at least not for long
#18 rik
rik
  • 2,187 posts
Posted 01 December 2008 - 10:41 AM
I spent £1650 on the parts, including timing + balance shaft chain changes £330 was the superchager + manifold from USA. You could be able to do it for £1200 minimum if you didn't bother with the chains and the dual pass plate etc..
#19 rik
rik
  • 2,187 posts
Posted 01 December 2008 - 10:42 AM
(new internals are needed)
#20 N17VES
N17VES
  • 560 posts
Posted 01 December 2008 - 12:18 PM
Good work Rik, you will have to show me sometime! Did you lower the compression by using a thicker head gasket and did courtenays remap the existing ECU, or did you fit a piggyback? You've got me thinking now.......
