My Diy Supercharger Build
43 replies to this topic
#21 mja182
mja182
  • 1,129 posts
Posted 01 December 2008 - 12:39 PM
Very nice work Rik! It amazes me how you will put your hand to anything. You will have to let me take a look at that bad boy come summer time. Did you get much advice/help from phoenix? Marcus thumbsup
#22 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 01 December 2008 - 12:44 PM
Would anyone be interested on working on a project of doing this with me? I have a friend who can bring over parts from america via freight as he working in the american automotive industry (group buy on super chargers anyone?), i also have another friend that can bring parts over in an APO for me which means 0 postage gernerally, or local postage at worst and no import charges. My dream project would be to find someone that would be able to fit these parts and then we could combine bringing them over and fitting. i am sure that doing two at once would mean much less hassle as we could copy from one to the other. I have little in the way of knowlege, but willingness to learn quickly! Dave.
#23 jasvxt
jasvxt
    Scary
  • 4,527 posts
Good lad Imnotworthy So how was it mapped ?
#24 Jameshs
Jameshs
  • 3,511 posts
Posted 01 December 2008 - 12:56 PM
Any chance you could pm me all the parts required as i fancy something to do over the winter
#25 techieboy
Posted 01 December 2008 - 12:57 PM
Dave.
I'm game to give it a try, Dave. thumbsup
Stick an intake manifold, gaskets and dual pass end plate for me, on the list of parts you're going to import.
#26 rik
rik
  • 2,187 posts
Posted 01 December 2008 - 01:55 PM
sent ecu to courtenays and they mapped it. I'm going over there in 2 weeks so they can check it + tune it any more if necessary mentioned it to phoenix before I fitted it and they asked if they could have a look at it when I took my car in for repair, they didn't have much to say but offered to help if I was stuck
Edited by rik, 01 December 2008 - 01:56 PM.
#27 rik
rik
  • 2,187 posts
Posted 01 December 2008 - 02:01 PM
The list of parts from my spread sheet
Supercharger + manifold
radiator
courtenay map
radiator piping
dual pass end plate
new bypass valve
injectors
wideband lambda sensor
map sensor
dyno time courtenay
injector plugs
idler pulley bracket
Header tank
belt
long alternator bolts
pulley
alignment bungs
sc oil
pulley puller
cam chain
balance chain
Air filter + pipes
#28 techieboy
Posted 01 December 2008 - 02:25 PM
Great job Rik. Can't believe it went together so painlessly for you - even without the garage. Where did you get the new connectors for the injectors and what MAP sensor have you used? Is the wideband lambda necessary? I've got a feck load of questions, maybe I should PM you. :D
#29 siztenboots
Posted 01 December 2008 - 02:27 PM
is this the build book you are using ?
http://tunersource.g...LSJ-Build-Book/
#30 rik
rik
  • 2,187 posts
Posted 01 December 2008 - 02:29 PM
Courtenay can supply the connectors and map sensor. Wideband not strictly needed, but nice to know it's fueling correctly the first time you start it
#31 techieboy
Posted 01 December 2008 - 02:32 PM
thumbsup
#32 rik
rik
  • 2,187 posts
Posted 01 December 2008 - 02:33 PM
I believe so, but I've never actually looked at the book. Got a lot of info from z22se.co.uk and cobaltss.net and of course courtenays
#33 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 01 December 2008 - 03:03 PM
top job mate! thumbsup
#34 rik
rik
  • 2,187 posts
Posted 01 December 2008 - 03:15 PM
Good work Rik, you will have to show me sometime!
Did you lower the compression by using a thicker head gasket and did courtenays remap the existing ECU, or did you fit a piggyback?
You've got me thinking now.......
no need to lower compression anymore, and courtenays can remap the ecu properly now, so no need for extra injectors or piggyback (that's what makes it more acceptable as a DIY thing)
#35 jasvxt
jasvxt
    Scary
  • 4,527 posts
Rik, I sense a business opportunity :D
#36 james141
james141
    Whiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiine
  • 3,667 posts
Posted 01 December 2008 - 03:21 PM
:yeahthat:
#37 EdButler
EdButler
  • 731 posts
Posted 01 December 2008 - 08:56 PM
Damn you Rik!! Beautiful work there mate... I'm very jealous indeed. I want another VX - anyone got a Cat D going (very) cheap!? lol
#38 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 01 December 2008 - 11:13 PM
:yeahthat:
Bagsy first customer.. ;) thumbsup
Top stuff rik, very impressive!
#39 forgotmepassword
forgotmepassword
  • 1,120 posts
Posted 02 December 2008 - 08:41 AM
Imnotworthy Sweet
#40 Astranomical102
Astranomical102
  • 614 posts
Posted 02 December 2008 - 02:44 PM
Watching with much interest thumbsup Imnotworthy
