Engine Replacement
#41
Posted 28 May 2009 - 05:55 AM
Not cheap but I wonder if you could drop one into a VX without too many mods. I'll ask him on Monday when I'm there.
#42
Posted 28 May 2009 - 08:22 AM
that depends WHICH M32 box you fit, I know which one is the best and thats what is going into my vx with my 7800 rpm z22seM32 wont make a Z22SE any closer to K20A
#43
Posted 28 May 2009 - 09:08 AM
http://www.swlotus.c...conversion.html
That's a great conversion and designed/manufactured very very well to use so much of the standard car, without needing any modification. It would just be totally wrong to stick a Ford engine in a Vauxhall though. The mongrel that is a Lotus can get away with it but would seem very odd in a VX.
#44
Posted 28 May 2009 - 09:30 AM
Ford Duratech?
I've heard this is becoming the conversion of choice now for the Elise. Steve Williams in Maidenhead was toying with dropping one into an S1 Elise he had lying around in his workshop, not sure if he did it. Easily tunable to 350bhp with a blower.
Erm... what does Nick's SC 2.2 run at again?
I would be curious to drive a silly power car. Not really sure how drivable something woth 300 or 400 BHP would be. I know I wouldn't want that much power in my daily driver VX, certainly not without TC but I guess for a lot of you these are just toys?
Vocky, with a 7000 or 7200 rpm hard cut I won't need to worry about replacing the final drive ratio will I?
Edited by rcvaughan, 28 May 2009 - 09:38 AM.
#45
Posted 28 May 2009 - 09:39 AM
VX LEGEND!
#46
Posted 28 May 2009 - 09:55 AM
Ford Duratech?
Erm... what does Nick's SC 2.2 run at again?![]()
But but but...with 400hp you would be able to make those awesome wheelies
#47
Posted 28 May 2009 - 12:18 PM
I would personally use a 4.17 final drive F23 with a 7200rpm rev limiterwith a 7200 rpm hard cut I won't need to worry about replacing the final drive ratio will I?
