Vx Na Tuning Mods
#61
Posted 24 March 2004 - 03:17 PM
#62
Posted 24 March 2004 - 03:29 PM
Every car seems to leave the factory with different settings
Cant imagine Scared Stiff does anything to the Caster. I lowered my car, measured it, and have made adjustments after that. Might perform a measurement to confirm my measurements, still for £10. Would be "Scared Stiff" if the bill was £140.
#63
Posted 24 March 2004 - 03:34 PM
#64
Posted 24 March 2004 - 03:41 PM
#65
Posted 24 March 2004 - 03:50 PM
#66
Posted 24 March 2004 - 04:01 PM
#67
Posted 24 March 2004 - 04:04 PM
#68
Posted 24 March 2004 - 04:05 PM
#69
Posted 24 March 2004 - 04:19 PM
#70
Posted 24 March 2004 - 05:10 PM
Made a small calculation:Is it though? The Viper has a carbon surround inside the cone, the aim of which is to shield the air from the heat of the engine - something not done by the standard airbox.Yeah, but I would skip the cold air induction, since it actually is "hot air"
If you have
-50 °C in the engine compartment
- 10 °C in the inlet air
- run the motor at 6000 rpm
- use a 70 mm dia plastic tube as inlet air duct of 0,5 m length
..then the temperature will increase 0,3 °C on its way to the engine
If you run the engine at 3000 the temperature will increase to 10,6 °C, see piccy!
So, I'm sorry you won't gain anything, but you will be stuck with a hefty bill. They rely on peoples reluctance to make any REAL changes, and just fit a conical carbon look filter.
#71
Posted 24 March 2004 - 05:17 PM
#72
Posted 24 March 2004 - 05:30 PM
#73
Posted 24 March 2004 - 05:34 PM
I'm not going to check your calculation as the maths degree was a bit too long agoSo, I'm sorry you won't gain anything, but you will be stuck with a hefty bill. They rely on peoples reluctance to make any REAL changes, and just fit a conical carbon look filter.
Am I right in thinking that the plain 'vanilla' car will just suck in air from the engine bay though, so that will be at the 50deg rather than 10deg?
Also, I understood the benefits of the Viper to be two fold - both the cold air feed as well as the shape inducing a swirling of the air entering the engine to create a ram type effect and increasing the airflow further.
I might be falling for the marketing spiel though!!
#74
Posted 24 March 2004 - 05:44 PM
#75
Posted 24 March 2004 - 06:04 PM
The technology used in the VIPER was first seen on the Lotus 340R, but now Pipercross are making it available for an ever increasing range of popular road cars. The cold air feed takes air from behind the grill straight into the VIPER’s 100mm diameter inlet, swirling it through a unique Pipercross velocity filter contained within a carbon fibre heat shield, and then into a ram pipe to increase it’s pressure before feeding it into the induction system
More power is achieved using the Viper compared to other induction kits because of two things. First, with the cold feed being at the front of the car, you benefit from the ram effect of the air being forced into the tube. This goes up as the square of the road speed. So you get four times the pressure force at twice the speed. What this really means is that the engine has an easier job sucking the air in, hence making it more efficient and therefore more powerful. (That's the ex-engineer coming out in me! - Colin).
The second benefit of the Viper is that cold air is fed into the engine from outside the car instead of under the bonnet where temperatures are high. Also, the carbon fibre heat shield protects the air charge from under bonnet heat. This means that the air entering the engine is more dense because it is colder and again it is then easier for the engine to suck in the amount of air it needs. So, in summary, what the Viper does is help the engine to gulp in the air more efficiently - hence more power.
#76
Posted 24 March 2004 - 06:26 PM
Edited by clipping_point, 24 March 2004 - 06:27 PM.
#77
Posted 24 March 2004 - 06:32 PM
#78
Posted 24 March 2004 - 06:35 PM
#79
Posted 24 March 2004 - 09:22 PM
Found this:
as taken and digested from BCBBS Archives:
340R settings:
ride height: front 100mm/rear 110mm
Excellent. How much of this can I do myself and how much needs to be done by a pro? I can adjust the ride height myself. Camber is with the aid of the shims but presumably you need to know what it is currently, before making changes?
#80
Posted 24 March 2004 - 09:38 PM
Also see:
http://www.vx220.org...t=ST&f=9&t=4540
