Vx Na Tuning Mods
84 replies to this topic
#81 Jase_MK
Jase_MK
  • 6,277 posts
Posted 24 March 2004 - 10:10 PM
I have adjustable Spax so can do the ride height and damping easily. I guess there is no point in adjusting the camber though unless you have a geo check first to tell you what the current camber is?
#82 clipping_point
clipping_point
  • 4,908 posts
Posted 25 March 2004 - 08:00 AM
Spax shocks, you lucky ba****rd!! No, once you have the ride height you want, you should perform a geo check. The alignment settings will change dramatically when you lower the car, I got more caster, camber and a terrible toe-out if I remember it correctly. Beware for the tyre wear!! The caster is a ba****rd to adjust but it can be done, but my value 3,4° is more than the standard 3,0 and less than the 340r figures.
Edited by clipping_point, 25 March 2004 - 08:01 AM.
#83 dude
dude
  • 1,404 posts
Posted 25 March 2004 - 01:54 PM
how did you manage to change caster??.
#84 garyk220
garyk220
  • 3,035 posts
Posted 25 March 2004 - 02:01 PM
Shims/washers are on the upper front wishbone mounting. Moving the shims from in front to behind the mounting will change the castor.
#85 dude
dude
  • 1,404 posts
Posted 25 March 2004 - 02:08 PM
hmmmm. i knew that. should start my brain before posting next time :rolleyes: :D
