Reduced Front End Lift
41 replies to this topic
#21 siztenboots
Posted 24 November 2009 - 01:12 PM
if someone has an accurate scale model , we have several wind tunnels here
#22 alanoo
alanoo
  • 1,324 posts
Posted 24 November 2009 - 01:23 PM
That's the key, the CAD model So, accurate 3D Scan -> CAD model then open doors to CFD softs and accurate scale models...
#23 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 24 November 2009 - 02:15 PM
Better pay for a full 3D Scan of a VX then stick it in a CFD software thumbsup
thumbsdown
Unfortunately you will also need to model the apertures, air intakes and what is behind them, and underside. Just modelling the closed top of the body from a scan is not sufficient for accurate CFD modelling.
#24 Winstar
Winstar
  • 4,264 posts
Posted 24 November 2009 - 02:22 PM
thumbsdown
not quite true, to get an exact figure for things like cd and lift then yes you would need an accurate representation of the 'underhood' however what you can do with a less detailed model is assess the merits of different aerodynamic features against one another.
#25 siztenboots
Posted 24 November 2009 - 02:29 PM
thumbsdown
mixing drag and against frontal area
CdA , Lotus Elise 1999 = 6.35 sq ft (0.590 m2)
#26 starlight
starlight
  • 1,790 posts
You would definately need an accurate front aperture and radiator model due to the significance of the flow going through there and up through the bonnet... Probably not so important for the engine bay area as you say, although the relative air bleed from the engine cover and through the rear wheel arches may play a significant role in the rear lift...
#27 Winstar
Winstar
  • 4,264 posts
Posted 24 November 2009 - 02:35 PM
as long as you where comparing against a baseline case and assessing the design changes then a representative shapes and flow paths would do, the loss though the front apature region is dominated by the flow characteristics of the radiator.
#28 slindborg
Posted 24 November 2009 - 02:45 PM
:yeahthat:
like going to a crappy/inaccruate RR.... aslong as you baseline it there and do subsequent runs with X mods there then its the difference you are after that matters, and not the exact figures :)
#29 starlight
starlight
  • 1,790 posts
Posted 24 November 2009 - 02:57 PM
VX220 NA
Cd = 0.38, FA = 1.6 sq m, CdA = 0.61
VX220 Turbo / VXR
Cd = 0.41, FA = 1.6 sq m, CdA = 0.66
oh and MIRA wind tunnel works out around £500/hr thumbsup
Edited by pjohn151, 24 November 2009 - 03:01 PM.
#30 siztenboots
Posted 24 November 2009 - 03:10 PM
VX220 NA
VX220 Turbo / VXR
cool i was looking for those figures to plug in to the data logger
#31 alanoo
alanoo
  • 1,324 posts
Posted 24 November 2009 - 05:06 PM
But you can do a model from a crashbox with simple hand tools
not possible for the whole car
#32 vxr36
vxr36
  • 1,179 posts
Posted 25 November 2009 - 08:45 AM
The non scientific approach... I found that the front of my car went light after fitting Nitrons and having a geo. Basically the effect of improving cornering performance meant that the back was left slightly lower than the front (proportionally speaking). I guess the top of the car must have been a wedge shape, producing some downforce, because it was definitely less as the 'angle of attack' was reduced. So it would make sense to lower the front or raise the rear to increase downforce at the front - Not a good solution as cornering would be compromised. Instead I put on the unsightly Astra G splitter, which is big and ugly but a little more forgiving than some on humps. It is a long time since I have had it fitted but I clearly remember that the stability was improved immensly.
Edited by vxr36, 25 November 2009 - 08:45 AM.
#33 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 25 November 2009 - 08:56 AM
You def want some rack on our cars height setup imo :) Like the look of the tms race car front splitter :P, just need a bigger rear wing to be sure :) I did think a while back about the angled wind deflector things you can attach to the front corners to give downforce - see them on a lot of time attack cars. But figured it may just slow me down if not done correct :(
#34 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 25 November 2009 - 12:40 PM
Just a matter of thought.... wasn't there a guy or team that were looking to use a VX for a project at Loughborough Uni? If so don't they have a pair of full-size wind tunnels and would they be any use... Might be time to make and then phone a friend?
Edited by Mangham54, 25 November 2009 - 12:41 PM.
#35 starlight
starlight
  • 1,790 posts
Posted 25 November 2009 - 01:19 PM
How about this one
#36 Mattias
Mattias
  • 300 posts
Posted 26 November 2009 - 01:59 PM
I'm working on a CAD model in Catia V5 at the moment but I'm not sure when it will be done. If anyone else want to have a go at it I'll post the bluprint needed here, and a picture of a car I made a few years ago :) Regars/ Mattias Attached File  speedster.gif   232.46KB   8 downloads Attached File  bild16.jpg   265.99KB   7 downloads
#37 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 26 November 2009 - 02:14 PM
Well done looks really good ;)
#38 Mattias
Mattias
  • 300 posts
Posted 26 November 2009 - 04:33 PM
Preview of work so far:
#39 Stefan_A
Stefan_A
  • 1,477 posts
  • Interests:Photography, british sports cars, diecast models, GT racing, whiskey, project management
Posted 26 November 2009 - 06:11 PM
The BADSTER boys are doing some serious rework, not very well suited for road use though...
#40 Exmantaa
Posted 27 November 2009 - 04:21 PM
Regars/ Mattias
Do you have that blueprint in another "editable" CAD format??
