Advice On A Lotus S1 Elise Sport 160
52 replies to this topic
#1 Porker
Porker
  • 307 posts
Posted 08 January 2010 - 09:44 AM
Hi all, I've been playing with the thought to change my VX220 for an Elise Sport 160. I would plan to sell my car after the upcoming trackday-season, if I get a decent price. The reason to change up (or down) would be the lighter weight. I was thinking, if you're going to sacrifice usability and comfort for the sake of lightweight, you might as well get the lightest possible Elise. It struck me during a trackday in Clastres how a Sport 160-owner could brake later, turn in quicker, ... Pro's for me: + Light + K-series engine + No Vauxhall Con's: - Risking potential costs again - Looks (beachbuggy) - I'd say reliability but I guess it'll be more of the same Any ideas on this? chinky chinky
#2 techieboy
Posted 08 January 2010 - 09:49 AM
The K series is a pro? Hmmm, not sure about that.
#3 SteveA
SteveA
  • 9,159 posts
Posted 08 January 2010 - 09:53 AM
Sport 160's are my fave elise Imnotworthy, nearly bought one with a K20 conversion a while back. Speaking to a guy who ran a K-series 160 for racing, he said they are a great engine to drive but can't take a lot of stick. He was talking about regular rebuilds etc.
It's still for sale!
http://www.pistonhea...les/1335983.htm
Edited by SteveA, 08 January 2010 - 09:55 AM.
#4 vocky
Posted 08 January 2010 - 10:08 AM
+ Light - slightly :poke: + K-series engine - are you serious :blink: + No Vauxhall - remove the badges :lol:
Edited by vocky, 08 January 2010 - 10:08 AM.
#5 Porker
Porker
  • 307 posts
Posted 08 January 2010 - 10:14 AM
Are we serious about commenting on the K-Series engine, while we're (at least the NA-guys) driving around in Z22SE's?? Let's not be blind for "our" own shortcomings...
#6 Porker
Porker
  • 307 posts
Posted 08 January 2010 - 10:20 AM
That's a very cool example, if it's still for sale by then, I'd consider it!! chinky chinky
I've heard the K-series requires to be maintained properly, but works well if you do...
The "joint-de-culasse" (don't know the correct word in English) appears to be quite sensitive.
#7 vocky
well at least once the z22se timing chain is replaced it's good for 100,000 miles, don't think the K series head gasket will last that long :P we are trying to convince you to keep your vx220, what else do you expect from us :D
Edited by vocky, 08 January 2010 - 10:21 AM.
#8 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 08 January 2010 - 10:23 AM
cylinder head gasket :rolleyes: = "joint-de-culasse"
Edited by crazyfrog, 08 January 2010 - 10:23 AM.
#9 Porker
Porker
  • 307 posts
Posted 08 January 2010 - 10:24 AM
I expect everyone to be car enthousiasts chinky chinky
What's up with the timing chain, when does one know when to replace it? I assume if you're too late, it's over and out for the engine?
#10 vocky
Posted 08 January 2010 - 10:25 AM
and there was me thinking that Fab would say 'buy throttle bodies' :rolleyes:
#11 Porker
Porker
  • 307 posts
Posted 08 January 2010 - 10:26 AM
Thanks.. That doesn't seem like to big a deal to replace by a proper one, or am I mistaken?
#12 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 08 January 2010 - 10:27 AM
:closedeyes: itb's are under snow :(
no work today Neil are you board :lol:
poor head is in the cold waiting for you to perform your magic :lol:
#13 vocky
Posted 08 January 2010 - 10:28 AM
we are, just a bit biased towards the vx220 :wub:
early engines before engine number 11064500 had a small oil jet fitted (2000, 2001 and early 2002 cars), if you ever hear a rattle from the engine on cold start it's best to get the timing chain kit replaced asap
#14 vocky
Posted 08 January 2010 - 10:31 AM
work :unsure: none of that until monday :D
your head is still waiting, maybe get stripped this weekend :P
#15 Porker
Porker
  • 307 posts
Posted 08 January 2010 - 10:32 AM
Thanks, I'll look into that! Mine's a 2001...
Maybe the previous owner had it done, I'll ask him about that (I've got 60.000mls).
Regarding K-series', are there examples which are better than others? I've read the K-series in the 111s is more problematic than others, for example...
By the way, why I wrote "K-series" as a "pro", I think the sound is just to die for (in 4-cilinder terms)...
#16 N17VES
N17VES
  • 560 posts
Posted 08 January 2010 - 10:41 AM
Frank - Timing chain and oil ject nozzle has been done on your car thumbsup
Nothing wrong with the K series engine. Very characterful (unlike the z22se!!), and quite easy to tune. Parts are also extremely cheap and easy to come by because they put they have put them in so many different cars. Porous head have been a problem, but if you look on SELOC there is loads of info about it.
Not sure if its worth the swap personally, but can see why you are considering it. I would drive one first because they are a step backwards in some areas.
p.s.
Sport 160 shouldn't be able to outbreak a vx220 on semi slicks!
#17 SteveA
SteveA
  • 9,159 posts
Posted 08 January 2010 - 10:43 AM
Over 100kg lighter.
#18 Yellow_or_black?
Yellow_or_black?
  • 12,905 posts
Posted 08 January 2010 - 11:00 AM
+ No Vauxhall
:lol: What does that have to do with anything?! If it bothers you that you're driving a Vauxhall, then I'd say you're prime Lotus material :tt: :D
#19 Winstar
Winstar
  • 4,264 posts
Posted 08 January 2010 - 11:06 AM
The head gasket goes because the cooling system is badly designed not because of the gasket.
If all you want the car for is the track then a 160 would probably be good, but I suspect it will cost you quite a bit more to buy on than a VX as they are pretty sort after
#20 Porker
Porker
  • 307 posts
Posted 08 January 2010 - 11:08 AM
p.s.
Thanks for your info Nick!
The guy with the Sport 160 is a regular on trackdays around here, I'll try and ask if we could swap for a couple of laps, just to see if it's worth it...
The Elise was on semi slicks too, and although I could brake late, I'm sure he did even later, but I must admit I haven't looked at his brakes, maybe they were upgraded... chinky chinky
