Best Induction Kit For Na
#41
Posted 28 February 2010 - 06:12 PM
#42
Posted 28 February 2010 - 08:28 PM
#43
Posted 01 March 2010 - 12:55 AM
Edited by Paulus H, 01 March 2010 - 12:59 AM.
#44
Posted 01 March 2010 - 11:10 AM
To Winstar:
You recommend removing the cone shaped barrel at the outlet of the airbox.
What purpose do that part have?
It seems to be a sort of restrictor or something.
Yes I have, there is some debate as to whether it forms a tuned length in the inlet and that removing it will cause a loss of torque. It's purpose is that it is a Noise reduction feature as the inlet system is a carry over from a Vectra (I think).
A better question would be, has anyone got pictures of the std intake system?
If it were not for the late hour, I would go into the attic and photograph my old intake system.
Vauxhall have quite a good reputation for inlet/airboxes but I really don't see how this system can work efficiently.
As an ex-auto engineer (HND in Automotive Design) and once an avid reader of David Vizards work (from 30 years ago), I think DV would be appalled by the VX design. I remember quite clearly many of the DV principles. I don't remember any of DV's drawings resembling anything like the std VX design.
As much as DV did some good work as you say it was 30 years ago and the automotive engineering world has moved on a whole lot since then. Once you've removed the NVH cone mensioned above and reduced the length od the inlet pipe to match the VX intake only has one real bad feature ant that is the slight S-bend but in reallity this won't cause much of a loss. Features like the offset inlet and outlet are so that the flow is slowed and evenly distributed as it passes through the filter. The flat pipe and cobra head is to try to get even flow either side of the throttle butterfly.
#45
Posted 02 March 2010 - 12:01 AM
#46
Posted 02 March 2010 - 08:13 AM
I just fitted an ITG today, standard airbox before.
All I can say is, Who the hell stole my VSE during the night?! I only really bought it (2nd hand) because of the noise and am very happy with that
Glad it turned up, pleased you fitted it and chuffed you are happy with it.
#47
Posted 02 March 2010 - 09:18 AM
#48
Posted 02 March 2010 - 09:30 AM
#49
Posted 02 March 2010 - 12:50 PM
Once again a broader question is why does this engine even modified with cams, head mods and ITB's produce such low specific HP?
because shes just not a revvy engine
Not saying they wont add anything lower down the rev range, but their influence is much mroe noticeable top end. and with a 7mile stroke like the Z22, you are fcuked unless you spend a mint like Vocky
#50
Posted 13 September 2010 - 02:30 PM
#51
Posted 18 September 2010 - 06:15 PM
#52
Posted 19 September 2010 - 09:53 AM
#53
Posted 20 September 2010 - 12:45 PM
#54
Posted 20 September 2010 - 09:23 PM
None of the above bodes well.
When I was running Thorney phase 2 I was very happy with the power delivery. I thought going for the ITG would be an improvement. Then I bought an ITG....
To begin with I kept chasing the red line because the car sounded awesome. At that time I thought the ITG was an improvement.
After a while I realized I was changing gear well before the red line because the power was trailing off early. This never happened prior to fitting the ITG.
With the benefit of hindsight I would say the car felt sportier to drive and had a more liner power delivery with the "strange" std induction system.
The sound was awesome with ITG but it hurt the power curve of the car.
I find it hard to believe but I recommend the strange std induction in preference to the ITG.
My car has additional mods now and has a great power curve as seen below. However I would not recommend the ITG unless you have at least 2.4 manifold....
Best regards, Paul...
Edited by Paulus H, 20 September 2010 - 09:29 PM.
#55
Posted 21 September 2010 - 09:27 AM
Pictures of std air box....
this ribbing will cause very little pressure loss in that locaton and are there to stop the pipe colapsing under vacume.
These ribs are there because the sides of the box would be like a rolf harris wobbel board with the engine vibrations and the air flow should go nowhere near them.
I'll give you the S bend that's inexplicable*, the corrugated section is required to take the (considerable) movement of the engine and the frictional pressure loss down a regular corrugated pattern is low as vortices form in the grooves.
*it was probable designed for another application and just dragged out the parts bin
#56
Posted 21 September 2010 - 11:42 AM
#57
Posted 21 September 2010 - 04:51 PM
#58
Posted 22 September 2010 - 12:43 PM
No one has mentioned K&N I dont think, thoughts?
I ran a K&N cone and it wasnt too bad at all. Nice little noise.
I changed to a viper and didnt really notice any difference
