ABS Switch
#41
Posted 22 March 2016 - 06:27 PM
#42
Posted 06 July 2016 - 01:06 PM
awesome will be doing this, thanks for adding the pics gaffer
#43
Posted 06 July 2016 - 05:09 PM
...just to add, I had terrible trouble with hard pedal, absolutely killed my confidence on track... last track day I turned off the ABS switch that I fitted 5 years ago and hey presto... brakes are absolutely bang on and consistant.
#44
Posted 06 July 2016 - 06:37 PM
You're welcome, makes a big difference. Let me know if you need help.awesome will be doing this, thanks for adding the pics gaffer
#45
Posted 07 July 2016 - 07:09 PM
Thanks dude. Just got it installed this evening huge difference. Would like to put a 4 channel abs pump in, maybe one day. I moved the toe hitch to other side and the switch fitted perfectly. http://imgur.com/5q3fg8nYou're welcome, makes a big difference. Let me know if you need help.awesome will be doing this, thanks for adding the pics gaffer
#46
Posted 17 July 2016 - 03:02 PM
My loom has been damaged, with a single torn wire right at the ABS plug. Yup, it's a yellow one. Now the cars in pieces at present, so I can't just flip the switch and see if the ABS light comes in. Would this yellow wire be the one by some stroke of luck??
#47
Posted 17 July 2016 - 07:08 PM
Best mod I ever did
leave it switched off.
#49
Posted 17 July 2016 - 07:46 PM
There are two yellow wires, one does ABS the other Tachometer (rev counter).Has anyone looked at which wire this 'yellow wire' actually is? from what I've read, folks have attacked the loom somewhere along it's length, and it's a case of 'this one or that one' and look at the dash? My loom has been damaged, with a single torn wire right at the ABS plug. Yup, it's a yellow one. Now the cars in pieces at present, so I can't just flip the switch and see if the ABS light comes in. Would this yellow wire be the one by some stroke of luck??
#50
Posted 18 July 2016 - 06:29 AM
shitty lighting in the warehouse... of the two yellow wires, one does indeed have a faint grey stripe.
stroke of luck that the only damaged wire is indeed the solid yellow one
#51
Posted 21 July 2016 - 06:04 PM
Edited by Doctor Ed, 21 July 2016 - 06:06 PM.
