Fuel Pumps And Swirl Pots...
Posted 10 April 2010 - 04:46 PM
joe 589:)
Posted 10 April 2010 - 04:50 PM
Edited by rcvaughan, 10 April 2010 - 04:53 PM.
Posted 10 April 2010 - 05:05 PM
Posted 11 April 2010 - 07:07 AM
Edited by Nev, 11 April 2010 - 07:09 AM.
Posted 11 April 2010 - 07:26 AM
Thx guys.
I am not keen on the big job of dropping the tank out of the bottom of the car to change the OEM fuel pump to cliffies one to be honest. It sounds like a tough job, though in all honesty its the best way of solving the problem as it reduces the number of parts to go wrong.
Is there anyone who's dropped a fuel tank before who can help me with this please ? *beg*
I'm going to 'learn' howto do it soon
I think its only a real problem if your some kind of cripple with non functioning limbs
Posted 11 April 2010 - 10:41 AM
Posted 11 April 2010 - 06:23 PM
Posted 11 April 2010 - 06:47 PM
Posted 11 April 2010 - 07:02 PM
few pics of mine..
I am running an ajustable fpr so I found a rail without the return feed (return feed now comes from the new fpr)
Posted 12 April 2010 - 12:05 PM
Posted 12 April 2010 - 12:34 PM
Thanks for the offer Stuart
Thanks for the kit offer Chris.
I didn't know about the pre-filter on the OEM pump, so I guess the best solution is to 'nibble' the hatch larger and drop one of your friends new pumps in. I guess I will have to go order a metal nibbler now and pray that I don't compromise the chasis strength.
Is there enough room to pop rivet the new larger hatch down properly so as to give a bit of strength back to the cut out area?
Edited by Nev, 12 April 2010 - 12:35 PM.
Posted 12 April 2010 - 12:38 PM
Obviously depends on how big you make the hatch. I replaced the orginal rivnuts with 6 or 7 new ones to bolt the new cover in properly. I'm confident it wont have done anything detrimental to the integrity of the tub. Sinclaire's also take this approach on the Elise/Exige when replacing the pump.Is there enough room to pop rivet the new larger hatch down properly so as to give a bit of strength back to the cut out area?
Edited by techieboy, 12 April 2010 - 12:39 PM.
Posted 12 April 2010 - 01:22 PM
Posted 12 April 2010 - 01:33 PM
Posted 12 April 2010 - 01:36 PM
Yep, I've got an air powered one (this was the excuse I needed to buy one). You're welcome to borrow it for a while, if you've got access to a compressor at home?Thanks Techie, do you have a metal nibbler at your place BTW ?
Posted 12 April 2010 - 02:46 PM
Posted 12 April 2010 - 03:50 PM
Posted 12 April 2010 - 05:21 PM
Thanks guys, and especially Cliffie.
I'm just going throght the trail and tribulations of fitting my Pro-Alloy fuel tank today, so I need to cut a hatch and drop the tank. For the guys that have done it, what size enlargement is necessary? As far as I can see the current hatch bearly uncovers the edge of the pump, and with an OD of about 150 mm, the hatch would have to be at least 160X160 mm to provide access to withdraw/drop the pump body and mounting flange in and out. A rectangular cut would of course be the easiest solution.
Thanks Dave
