Supercharger Build
79 replies to this topic
#1 chris_uk
Posted 14 May 2010 - 01:24 PM
Im planning on making a build thread on the supercharger installation, hopefully lots and lots of pics and good info for you all.
So i came home today to find 2 massive boxes!
1 had the big chargecooler and pipework, the other all the bits you are about to see.
This is everything i got from the courtenays kit.
Here is a group pic of pretty much everything
1. -
2. - Gromits for charge cooler pipes
3. - Gasket from intake manifold to block
4. - charge cooler pipe clips
5. - Assortment of bolts
6. - Bolts
7. - Bracket
8. - Cover
9. - Intake manifold bracket
10. - assortment of j-clips
Edited by chris_uk, 14 May 2010 - 01:25 PM.
#2 chris_uk
Posted 14 May 2010 - 01:25 PM
11. - s/c belt (1270)
12. - Fused relay
13. - push fittings
14. - assortment of wiring
15. - wire sleeving and intake pipe
16. - Fabric tape
17. - 90deg Pipes
18. - x4 Injector plugs
19. - Injectors
20. - Intake pipe
#3 chris_uk
21. - Temp sensor
22. - Tensioner
23. - Map Sensor
24. - Intake Manifold
25. - Duel Pass Mod
26. - Supercharger
27. - Supercharger
Edited by chris_uk, 14 May 2010 - 01:30 PM.
#4 smiley
Posted 14 May 2010 - 04:20 PM
Nice, i love these detailed builts thumbsup
#5 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 14 May 2010 - 04:27 PM
get croaking:rolleyes:
#6 chris_uk
Posted 14 May 2010 - 05:26 PM
what charge cooler pumps have you lot used? i dont think i was supplied one.
#7 zimmer
zimmer
  • 573 posts
Posted 14 May 2010 - 05:39 PM
Will be watching this with interest chris, good luck
#8 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 14 May 2010 - 06:48 PM
When are you starting it Chris? Might bob over to pass you spanners/make tea if I can get away :)
#9 chris_uk
Posted 14 May 2010 - 06:54 PM
ill be starting this on june 15th, i was going to ask you to pop over anyway so i can try decipher where some bits go etc. free tea/biscuits and pizza probably :)
Edited by chris_uk, 14 May 2010 - 06:54 PM.
#10 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 14 May 2010 - 07:11 PM
you havnt got a pump in picture Chris go on ebay bosch water pump or demon tweeks thumbsup
How much you pay for all that? from Courtney i bet more than i could have done the conversion for ;) Good luck with it need any help just give me a pm mate thumbsup
There are some nice cosie 75mm air filters on ebay pipercross ;)
Edited by leevx2.2, 14 May 2010 - 07:13 PM.
#11 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 14 May 2010 - 07:14 PM
What a lovely collection of parts. Best of luck with the build, if you were closer I would love to bring the biccies. Keep us informed and it will be worth it.
#12 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 14 May 2010 - 07:21 PM
I'll see what I can do mate drop me a line nearer the time
#13 chris_uk
Posted 15 May 2010 - 05:05 PM
i paid 3269.58
that included the larger pre-rad and duel pass mod
#14 chris_uk
Posted 15 May 2010 - 05:08 PM
a question tho.. on some pics ive seen the map sensor ontop of the charger, but on some there is the small blanking plug (like the 2 locator plugs but sealed) why is this?
#15 The Batman
Posted 15 May 2010 - 05:10 PM
you cnt use the map sensor on topof the charger you have to have the 2bar sensor that courtenays charge and fit it to the inlet manifold :)
#16 chris_uk
Posted 15 May 2010 - 05:17 PM
ok so if i put it in the manifold, what is meant to plug the hole up and the plug that i was on about is very loose in the hole.
#17 Phear
Phear
  • 1,125 posts
Posted 15 May 2010 - 05:41 PM
Courtenays do a plug for the SCIP (Supercharger Inlet Pressure) hole on the top of the charger. However it is a rip off for what it is, a small piece of metal or suitably sized bolt and some glue will surfice. The 2 bar MAP sensor that courtenays provide is too small for the hole on the top of the inlet manifold as standard. I removed the orange rubber around it, layered up some electrical around it and then stretched the orange rubber over the tape thus increasing the diameter until it was a snug fit. As an extra precaution I also sealed it in with some silicone gasket sealant but that was just me going overboard. I also modified the bracket holding the SCIP inplace to use to hold the MAP sensor in place.
#18 chris_uk
Posted 15 May 2010 - 06:24 PM
right cheers, thats cleared 2 questions up that i had.
2 other questions: the pipe that comes from the supercharger near the throttlebody, where does that go? and the tiny pipe from the inlet manifold, whats this for? (it was covered in a yellow tube)
#19 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 15 May 2010 - 06:46 PM
The pipe on the back of t/b goes to charcoal canister pipe the bigger one on the front goes to the servo pipe.and the tiny pipe on the intake to the fuel rail thumbsup
Edited by leevx2.2, 15 May 2010 - 06:47 PM.
#20 chris_uk
Posted 15 May 2010 - 06:58 PM
cheers lee :)
