Supercharger Build
#41
Posted 18 June 2010 - 09:26 PM
#42
Posted 18 June 2010 - 10:37 PM
well little update..
i plugged the battery on the car for about 5 seconds as plumes of smoke appeared from the rear..
what i had done is caught the live wire going to the altenator on the manifold, luckily it was just the sheething on the wire that melted, it wasnt on for long enough to do much more damage luckily.
ive not recovered it and made sure its well out of the way.
on a positive note, the car is done, well the only thing left to do is mount ecu, plumb in the header tank and wire in the relay for the charge cooler pump and we are ready to go.
LOL that is EXACTLY what mine did as well
Halfords do the EXACT right cable for about £3...!
#43
Posted 18 June 2010 - 10:45 PM
Edited by chris_uk, 18 June 2010 - 10:46 PM.
#44
Posted 19 June 2010 - 07:24 AM
#45
Posted 19 June 2010 - 09:31 AM
how did your new belt go today? have you got it yet?
Lol, I'll let you know how that goes later...
#46
Posted 19 June 2010 - 03:14 PM
#47
Posted 19 June 2010 - 05:55 PM
#48
Posted 19 June 2010 - 09:17 PM
quick question, and quick pic,
when im plumbing up the chargecooler pipes etc, does this look about right?
the charger i got from courtenays, well the entire job lot i got from them tbh,
Is it just me or would it mot better if the 'hot' water to the rad, then the cooled return into the header tank and the output of the header is pumped into the manifold ?
as it stands it just looks like the header tank will heat soak :s
#49
Posted 19 June 2010 - 09:23 PM
It's arguably if this routing brings a bit cooler water directly to the cores, as the tank can heat up a bit by hot exh. air. But for the above reason I routed it: Tank bottom > Pump > Laminova's > CC > Tank top.
Should make for a small supply of cooled water...
#50
Posted 19 June 2010 - 10:33 PM
#51
Posted 21 June 2010 - 04:11 PM
#52
Posted 21 June 2010 - 04:56 PM
#53
Posted 21 June 2010 - 09:36 PM
#54
Posted 22 June 2010 - 07:39 PM
#55
Posted 22 June 2010 - 08:19 PM
#56
Posted 22 June 2010 - 11:17 PM
Edited by chris_uk, 22 June 2010 - 11:21 PM.
#57
Posted 23 June 2010 - 09:23 AM
#58
Posted 23 June 2010 - 09:44 AM
Is that down to your trapped wire? Thank feck it didn't toast the ECU as well.the battery light is 99% a buggered alternator
the engine staying on is the relays in the boot which are goosed.
Good idea on their part to stick a low rev-limit on this remote remapping. I wouldn't mind something similar on 1st and 2nd on my car anyway.
#59
Posted 23 June 2010 - 10:32 AM
the rev limits under load are normal, courtenay have started putting a very low limit on to save the cars from damage before they see them.
Really? Mine is 6500 and I only got mine done a few months back.
#60
Posted 23 June 2010 - 12:30 PM
