Scangauge
56 replies to this topic
#1 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 05 July 2010 - 11:31 PM
Sorry if this has already been asked, but I just want to be sure etc.
If i get a Scangauge, is this the one I need http://cgi.ebay.co.u...377ec67fe699054
Is it as simple as plugging it in to the plug socket that's by the passenger footwell ?
I want it to be able to switch the cooling fan on & off manually.
Is it just a case of entering the following codes in, and that's it ?
C433F130130700
Accept that and go to Memory 2, put this code in
C433F1301307FF
fan on = Memory 1
fan off = Memory 2
Please let me know, so I know what to order, and what to do when it arrives ?
#2 Sammy
Sammy
  • 1,206 posts
Posted 06 July 2010 - 06:03 AM
Yep, Just go through the menu until you see CMDS, enter, than put them in the memory. Couldn't be simpler. :)
#3 Harry0075
Harry0075
  • 690 posts
  • Interests:Cars (Classic + Sportscars), Running, Cycling, and Discovery Turbo!
Posted 06 July 2010 - 06:09 AM
:yeahthat: yep, looks exactly the same as my scangauge...i have Memory 0 = fan ON...and then memory 1 = fan OFF. give us a shout if you get stuck, its pretty simple though. chinky chinky
#4 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 06 July 2010 - 07:11 AM
Or you could buy it from www.ukobd.com there is also a discount code as well for them giving10% off I think it was
#5 redvts
redvts
  • 1,472 posts
Posted 06 July 2010 - 11:17 AM
Just put these codes in my sg. Any other useful codes worth putting in?
#6 techieboy
Posted 06 July 2010 - 11:20 AM
Yours is a turbo, isn't it? Didn't think those codes worked for the turbo. Good news if it does. I'm sure there is an equivalent fan switching code for the turbo's ecu but not sure anyone has discovered it yet. Maybe Courtenay or Klasen will know what the hex string is. :unsure:
#7 tommobot
tommobot
  • 1,008 posts
Posted 06 July 2010 - 11:56 AM
Wow. Didn't know you could do this. I shall give it a go later..
#8 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 06 July 2010 - 11:59 AM
Thanks guys for the advice (and reassuring).
I have just ordered one.
I'll post the results on here when it arrives Posted Image
#9 redvts
redvts
  • 1,472 posts
Posted 06 July 2010 - 12:03 PM
ur right! just tried it, didn't work damn it :wacko:
#10 Guest_VX220Dallan (Guest)
Posted 06 July 2010 - 03:08 PM
seems a rather expensive mod if you JUST want to turn the fan on and off :/ :/ :/
#11 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 06 July 2010 - 03:17 PM
No, not just that. With all the other info etc that it gives, I think it's a rather good deal.
Plus it's easy to install - which suits me ! Posted Image
#12 Guest_VX220Dallan (Guest)
Posted 06 July 2010 - 03:19 PM
yeah true, soz mate, didnt mean it to sound as bad as when i re-read it!! - lol
your about to see my scanguage thread now - lol#
#13 The Batman
Posted 06 July 2010 - 03:21 PM
dont think the scangauge works with the itbs pre historic ecu :P
#14 DarrylB
DarrylB
  • 1,629 posts
Posted 06 July 2010 - 03:22 PM
I have mine set up exactly like that! Mem 1 turns the fan on, Mem 2 turns it off. I have also added the X-gauges of BHP and AF Ratio just because I can, just a bit of fun.
#15 Guest_VX220Dallan (Guest)
Posted 06 July 2010 - 03:23 PM
thats pretty good idea :D :D
#16 Guest_VX220Dallan (Guest)
Posted 06 July 2010 - 03:24 PM
B
O
L
L
O
C
K
S
#17 Trevsked
Trevsked
  • 171 posts
  • Interests:Classic cars, R/C jets.
Posted 06 July 2010 - 09:24 PM
Darryl, Any chance I can have a look at your scangauge and you show me how it works?. Sounds interesting. Either you can come to me or I to you. Trevor.
#18 tommobot
tommobot
  • 1,008 posts
Posted 06 July 2010 - 09:57 PM
Eh? Whats this now? :mellow:
#19 DarrylB
DarrylB
  • 1,629 posts
Posted 07 July 2010 - 08:44 AM
Darryl,
Trevor.
Sure can, although it's pretty easy to program it once you know what codes to put in. I'll dig em out, Where are you based? EDIT: Just seen yours is a turbo, will see if I can find out if the same codes work
You can add extra gauges on your scangauge - as long as your make of car can read the settings of course. These extra gauges are called X-gauges. once you know the codes for your car it's just a case of bashing them in. The x-gauges can then be cycled through on the main gauge screen along with the standard ones. I believe you can also program fuel trim percentages or similar?
Edited by DarrylB, 07 July 2010 - 08:46 AM.
#20 Trevsked
Trevsked
  • 171 posts
Posted 07 July 2010 - 09:23 AM
Darryl, Batchworth Heath near Harefield/Rickmansworth. I di wonder if the Scan gauge AFR worked on the turbo. I see there is also a very similar item called a Turbogauge Ebay item 150440345523 anybody any experience/thoughts? Trevor.
