...Off to try it out soon !
Posted 08 July 2010 - 09:43 AM
Posted 08 July 2010 - 09:48 AM
Posted 08 July 2010 - 11:27 AM
...Mine is a NAthe fan on/off codes don't work for the turbo.
Posted 08 July 2010 - 11:37 AM
...Mine is a NA
Posted 08 July 2010 - 02:37 PM
Edited by 2.2_na, 08 July 2010 - 02:38 PM.
Posted 08 July 2010 - 02:41 PM
Posted 08 July 2010 - 02:45 PM
Yep, CMDS menu.
Is your engine running? The fan commands don't work if the engine isn't running when you send them.
Posted 08 July 2010 - 02:51 PM
Yep, CMDS menu.
Yeah, the engine was running. I pressed send with the ON code, the fan didn't (appear to) come on - and it displayed a different code on the screen, is that right?
Am I doing something wrong?
Posted 08 July 2010 - 02:55 PM
hmmm give me 5 mins to pop down to the car park, start the car and check what codes I have.....
Posted 08 July 2010 - 03:09 PM
Posted 08 July 2010 - 03:12 PM
Right in the CMDS menu if have this:
Memory 1: C4 33 F1 30 13 07 FF (this turns it on)
Memory 2: C4 33 F1 30 13 07 00 (this turns it off)
For the BHP Xgauge (pick any number to edit as they are all blank)
TXD = 00
RXF = 40 00 80 00 00 00
RXD = 0000
MTH = 00 0A 00 17 00 00
NAME = BHP
For the AFR Xgauge
TXD = C3 33 F1 22 11 9E
RXF = 04 62 85 11 06 9E
RXD = 3008
MTH = 00 01 00 01 00 00
NAME = AFR
If that doesn't work the fan then are you sure that your fan is working?
Posted 08 July 2010 - 04:04 PM
Posted 08 July 2010 - 04:15 PM
Edited by 2.2_na, 08 July 2010 - 04:17 PM.
Posted 08 July 2010 - 04:19 PM
Posted 08 July 2010 - 05:15 PM
Edited by Mangham54, 08 July 2010 - 05:15 PM.
Posted 08 July 2010 - 05:34 PM
How audible is the fan?
Try pumping those codes into mine and no joy!
Get the following code after 'send'ing the code:
83F1117013070F.
Can't feel any breeze either!
Posted 08 July 2010 - 05:56 PM
Posted 08 July 2010 - 06:03 PM
Well I can't see owt wrong with the code, is there a particular setting/version for the X-Guage that we should be using?
Mine seems to suggest that there are a few xguage settings that can be used!
Posted 08 July 2010 - 06:09 PM
I only got mine working today, so I'm probably not the best person to be saying anything...but the fan on / off codes are (to my knowledge) not entered in the Xgauge settings.
They need to be entered in the CMDS settings, and stored in any of the memory locations 0 to 9.
Posted 08 July 2010 - 06:17 PM
[ Never heard the fan on mine so it could be that the fan is broken
