Need A New Key? Less Than A Tenner...
94 replies to this topic
#1 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 27 January 2011 - 08:22 PM
In my pursuit to avoid the dealers like the plague I contantly look for alternatives to the day to day problems of running a VX. This time it's the spare key issue. Originally I had thought that they were only available from the dealers because they have a transponder chip in them and would need coding to the car. This would cost you £27 for the key, then £30 to programme it. (That is assuming you have the Security Pass which is another £30 if you haven't!)
Then I found that I could buy a key from the dealers unprogrammed, for £27 and programme it myself with my OP-COM reader. Money saved, and I was quite pleased with myself at that point.
However, now I have found >these< on eBay which are identical to the VX key (ours are the '296' type and sometimes this is stamped into the key) for £9 delivered, then can be cut for a couple of quid locally then programmed via the OP-COM reader. Win, as they say thumbsup
For info purposes this is the Security Pass which normally is with the leather owners folder, and is the size as a business card;
This is the aforementioned uncut transponder key
OP-COM reader (plugs into the car, then into your laptop via USB cable) which are £25 from eBay
and the dealer
#2 techieboy
Posted 27 January 2011 - 08:28 PM
and the dealer
Sorry but had to quote that pic.
#3 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 27 January 2011 - 08:31 PM
Nice one thanks! Oh and hahaha :)
#4 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 27 January 2011 - 08:32 PM
Top man Mr P4cks. Just ordered two, so need to order the card from Vauxhall and then I may have to pop round to yours and let you programme mine.
Beer will be offered.Posted Image
#5 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
And the process from the Op-Com is what? I am really daft so speak s-l-o-w-l-y please.
#6 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 27 January 2011 - 08:34 PM
Can you program the key just using the code in your security pass then? I need a spare for mine :)
#7 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 27 January 2011 - 08:35 PM
Technically Jon it is the other way round. The key has a fixed code and you programme the car to accept the immobiliser chip in the key.
#8 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 27 January 2011 - 08:37 PM
Thanks, now I understand. So you will need two new keys with the same code otherwise your original key will not work...?
#9 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 27 January 2011 - 08:38 PM
Deal. I need the Pass too. Might go for it this weekend if I have time. Remember though, you will need the V5 and proof of your identity to show the dealer.
The OP-COM plugs in to the car's ECU (in the passenger footwell) and to a laptop to the other end. When the OP-COM programme is open on the laptop there is an option to programme a new key. The key needs to be cut, and in the ignition with the ignition on. Once you've typed your security code into the laptop, it will send a signal through the OP-COM reader into the ECU and into the key so it programmes it to your ignition.
#10 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Right so you need the car. What other uses does the OPCOM have? Fault code reading? Might be worth getting one
#11 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 27 January 2011 - 08:39 PM
Yep. Needs cutting first though, of course.
#12 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 27 January 2011 - 08:40 PM
Fault code reading and warning light resetting. Very useful and especially as the whole thing costs less than the dealers charge for just plugging the fucker in at their place.
#13 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 27 January 2011 - 08:41 PM
I have an ODB reader actually do I just need the program for the laptop in that case? (cough cough)
#14 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 27 January 2011 - 08:46 PM
Downloadable from the internet I believe.
#15 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 27 January 2011 - 08:48 PM
Just aquired something called OP Tech 2 should that do the key programing?
#16 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
>Correct<. Bottom of the page.
#17 theotherjonnymac
theotherjonnymac
  • 7,434 posts
Posted 27 January 2011 - 08:49 PM
The joys of ebay. What did we do before it chinky chinky
#18 techieboy
Posted 27 January 2011 - 08:50 PM
Good luck getting that to work. thumbsdown
I never managed to get OP-COM working with a generic OBDII interface. Worked a treat the soon as I bought an OP-COM branded one of eBay for £10 though. YMMV
#19 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 27 January 2011 - 08:54 PM
Not necessarily, no. As long as you have the security code, a lap top and the OP-COM you can programme any new key with a transponder.
#20 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 27 January 2011 - 08:55 PM
cheers p4cks will give this a go at the weekend
