Can you re-code an old key?
So you will need two new keys with the same code otherwise your original key will not work...?
Not necessarily, no. As long as you have the security code, a lap top and the OP-COM you can programme any new key with a transponder.
Need A New Key? Less Than A Tenner...
#21
Posted 27 January 2011 - 09:22 PM
#22
Posted 27 January 2011 - 09:41 PM
#23
Posted 27 January 2011 - 09:44 PM
#24
Posted 27 January 2011 - 10:02 PM
#25
Posted 27 January 2011 - 10:20 PM
That is assuming you have the Security Pass which is another £30 if you haven't!
Does this mean you can actually buy a replacement Security Pass card??
#26
Posted 28 January 2011 - 07:21 AM
The transponder chip has a different code than Corsas and other Vauxhalls.
Not on these ones. The one I linked to is the 'D-Series' transponder which is in the VX220 key.
See page 48 >here<.
No, just a new one.
Edited by p4cks, 28 January 2011 - 07:21 AM.
#27
Posted 28 January 2011 - 08:33 AM
Well bugger me, I never knew that. Thanks for that info
, where from? Any Vauxhall dealer?
Certainly does. You need to bring about £32, your V5 and your drivers license (to prove address) to any Vauxhall dealer and they should get it in 3-4 days
Hmm, bet you could use this key and blipper to replace the existing seperate key and alarm fob arrangement
(Im sure guy did something similar yonks ago only with a 'flip out' style key)..
http://cgi.ebay.co.u...=item25602963a4
and
http://cgi.ebay.co.u...=item255b578801
Seems its the right transponder type due to the 296 (If I understand correctly..)
The '296' is just the shape of the actual key. The important bit is that the transponder is the D-Series. So you need to find a 296 shape key with the D-series transponder for it to work with the VX.
#28
Posted 28 January 2011 - 11:21 AM
#29
Posted 28 January 2011 - 12:08 PM
Right so you need the car. What other uses does the OPCOM have? Fault code reading? Might be worth getting one
I've got one if it doesn't work
Edited by Winstar, 28 January 2011 - 12:12 PM.
#30
Posted 31 January 2011 - 01:14 PM
#31
Posted 31 January 2011 - 01:31 PM
#32
Posted 31 January 2011 - 02:18 PM
#33
Posted 31 January 2011 - 02:19 PM
yes m8 the programming picks up the code from the chip thats in the key so if you dont tell it to accept the chips code it wont unlock the immobiliser.
perfect thanks, thats a key for the misses sorted
#34
Posted 31 January 2011 - 02:23 PM
#35
Posted 31 January 2011 - 07:29 PM
Sssshhhh!Comment
Otherwise we'll find that all our petrol tanks get emptied by half-inching twats.
#36
Posted 31 January 2011 - 07:55 PM
iirc any key will open the fuel cap
Will one of those suitcase padlock keys work?
#37
Posted 31 January 2011 - 09:33 PM
#38
Posted 01 February 2011 - 07:20 AM
Correct type, but uncut, keys don't work... They almost do, but not quite.
#39
Posted 04 February 2011 - 06:59 PM
I got my Security Pass today and programmed my key successfully with the OP-COM, so it can be done
#40
Posted 04 February 2011 - 07:03 PM
UPDATE:
Looks like your gonna be getting a few beers soon.
