Hub Carrier Bolts - Pics Please
Posted 14 February 2011 - 05:11 PM
Posted 14 February 2011 - 05:32 PM
Posted 14 February 2011 - 05:37 PM
Edited by Ouchie, 14 February 2011 - 05:39 PM.
Posted 14 February 2011 - 07:49 PM
Um, they are bolts. They undo and do up again
Replace one bolt at a time, it's easier and shims won't fall out or get lost easily.
You will need a tap set to clean out the threads once the old bolts are out - this contradicts the above shortcut though.
Best to use some locktight stuff on the new bolts.
Tools:
Jack
Wheel nut remover and key
Hex head bit (6mm???)
Ratchet
Possibly a long handled ratchet or long bar for tough bolts
Fronts are easier than the rears due to being able to play with steering angle to aid access.
I've got a set of these, 10.9 grade to fit. Anyone know the size and thread pitch for the tap?
While I at it and as I need to but a tap set, anyone know what size and pitch for the wheel bolts - my bolts are in a state need to replace but not worth it unless I clean out the hub.
Posted 15 February 2011 - 12:37 AM
Posted 15 February 2011 - 12:47 AM
Hammer in a Torx bit thats a very tight fit, never let me down.One of mine (rear nearside front bolt) has rounded when Courtenays tried (and failed) to remove it. Any suggestions as to how to get it out anyone.
Posted 15 February 2011 - 09:35 AM
Posted 15 February 2011 - 10:03 AM
Are the mentioned 10.9 grade bolts a standard fit on a vxt or are these an uprated item?
If uprated bolts are they a recommended upgrade?
Thanks in advance.
The 10.9 are uprated items. I think standard fit was something like 8.8
Yes they are recommended. I think 'CLIFFIE' can still supply them - send him a PM
Posted 15 February 2011 - 10:29 AM
up to you but there is a picture somewhere of mine being tow away from the national 2010
done all the work now and feel more confident
Posted 15 February 2011 - 11:01 AM
Yes, thanks, that's top of my list to try, perhaps with some heat also.
Posted 15 February 2011 - 11:02 AM
Thanks in advance.
The 10.9 are uprated items. I think standard fit was something like 8.8. Basically the 8.8 are more likely to stretch or shear than the 10.9.
If Cliffie doesn't have any give me a shout as I have a set left over from the group buy.
I ended up getting a set of 12.9s fitted by Guglielmi, overkill perhaps but was getting lots of other work done and he threw them in for free. As it happened 2 of the old bolts sheered and needed to be drilled out
Posted 15 February 2011 - 11:44 AM
Posted 15 February 2011 - 11:48 AM
Access to rears is tricky so probably no room to swing a hammer with suitable force, undoing the tie rod is also a pain but will mean you can swing the hub around. The handbrake cable causes issues too.
Yes, thanks, that's top of my list to try, perhaps with some heat also.I just wondered if there were any other ideas. I'm also wondering if there's enough room to get sufficient swing at the torx to hammer it in or if I may have to remove the tie rod end. Failing that I may have to drill bolt head out and separate it that way. I really don't want to have to go down that route though.
Edited by Ouchie, 15 February 2011 - 11:52 AM.
Posted 15 February 2011 - 12:13 PM
Thanks in advance.
I ended up getting a set of 12.9s fitted by Guglielmi, overkill perhaps but was getting lots of other work done and he threw them in for free. As it happened 2 of the old bolts sheered and needed to be drilled outNot sure how common this is but glad I didn't try to change them myself
Can't multi quote on phone but thanks all. I'd have got a set off you (Cliffie) but shame your out of stock, hope you don't mind if I get the above set that are going spare from the group buy that I must of missed. I've got some uprated suspension to have fitted soon so would probably make sense to get the bolts changed at the same time.
Are there recommended torque settings for the 10.9 bolts or is it just a case of do them up tight?
Cheers.
Posted 15 February 2011 - 12:16 PM
68Nm + threadlockAre there recommended torque settings for the 10.9 bolts or is it just a case of do them up tight?
Posted 15 February 2011 - 12:36 PM
EVERY nut and bolt on body, engine, transmission, driveline, steering and suspension will have a recomended torque. The links to the manuals are on the site.
Posted 15 February 2011 - 01:04 PM
Although just about all of the fasteners on the car can be done up by feel and no need to fcuk about with a torque wrench... Headbolts and HCB's get torque'd to the 'book' the rest is a touchy feely exercise
Posted 15 February 2011 - 08:54 PM
Ooooh a man after my own heart, I always tighten to F-Stop using the touchy feely method on my car. Of course customers cars are a different matter.
Edited by Cliffie, 15 February 2011 - 08:55 PM.
Posted 16 February 2011 - 09:01 PM
Borg, I agree with a lot of what you say (and like the succinct way in which you deliver itIf you feel you cant do the job without a guide, I really think you should pay someone to do it.
I first started working on my car when I saw some total chimps at kwik fit changing the brakes on my Laguna, and thought 'if they can do it then I am sure as hell I can'. If you do your research (as the OP is doing here), ensure you have all the tools you need and know what can go wrong and ensure you have contingency for those eventualities then fair fcuks for getting stuck in I say.
Posted 16 February 2011 - 09:25 PM
Thanks for that, I'll get mu lump hammer out.
