Would you be concerned that 12.9s are not fit for purpose, CliffieThe 10.9 is the recommended upgrade, the 12.9 have a higher torsional shear but lower lateral shear.
Sadly not in stock but will order another batch soon.
Posted 18 February 2011 - 02:20 PM
Posted 18 February 2011 - 04:57 PM
68Nm + threadlock
Are there recommended torque settings for the 10.9 bolts or is it just a case of do them up tight?
Posted 18 February 2011 - 05:50 PM
That's according to the Lotus service bulletin but not sure whether that's the Bible, so to speak.
68Nm + threadlock
68Nm?? I was told 90Nm.... Hmmmm what to do now, replace them again??
Posted 19 February 2011 - 08:29 AM
Sadly not in stock but will order another batch soon.I tend to drive quite slowly on the road but enjoy a good blast on track now and then
Posted 19 February 2011 - 08:39 AM
Posted 19 February 2011 - 08:51 AM
So with the 10.9's having a higher tensile strength it should be ok to torque to 90Nm?
Posted 19 February 2011 - 09:11 AM
Posted 19 February 2011 - 10:31 AM
Posted 19 February 2011 - 10:57 AM
Posted 19 February 2011 - 11:37 AM
Posted 21 February 2011 - 10:13 AM
I'd not run any suspension component with 12.9's fitted..... imho more of a risk than running poorly torqued up 8.8's
Posted 21 February 2011 - 01:24 PM
Posted 21 February 2011 - 01:42 PM
Posted 21 February 2011 - 01:52 PM
Posted 21 February 2011 - 02:09 PM
What this needs is an engineers opinion. I supply the 10.9 bolts as that is the Lotus spec upgrade.
When I looked into this first time out, I was advised 12.9 would not be a good bet as the bolts are subjected to a side loading when on track on sticky tyres and the 12.9 are more prone to shearing when subjected to side loads whereas the 10.9 would have more flex.
Saying that SteveA runs the 12.9 and he doesn't hang about on track.
I will continue to only supply the 10.9 even though 12.9 are cheaper and available in the UK off the shelf whereas I have to order in the 10.9 from Europe.
Posted 21 February 2011 - 03:10 PM
Cliffie could you supply the uprated camber shims FLD recommended along with uprated 10.9 bolts as a kit?
Thanks a lot.
Posted 21 February 2011 - 04:44 PM
Would like to see pics for future referenceNo idea on 12.9's but you should also consider swapping the camber shims when doing the HCB's. The oe ones with one hole and one slot are quite soft and have a habit of almost extruding out at the slot end resulting in a loss of the torque setting on the bolt. I've got my suspension in bits at the mo and both front sides have done this and the bolts had a slight wobble in them. Lotus supply a hardened camber shim with holes both ends that is supposed to stop this problem.
I suspect this was the cause of my HCB failure last year. I'll put some pictures up when I can be ar5sed and if my camera will do justice to the problem.
Thanks SteveI've had 12.9's on my car for three years, do a fair bit of tracking on sticky tyres and have never had any problems.
Has anyone actually heard of a failure on 12.9's or is this just another bit of hearsay?
Thanks CliffieWhat this needs is an engineers opinion. I supply the 10.9 bolts as that is the Lotus spec upgrade.
Posted 21 February 2011 - 10:09 PM
Yes. 68Nm.
Posted 21 February 2011 - 11:18 PM
