Pikey mod.And before anyone notices .... the drivebelt was a 6PK750 from a VW Polo 1.3 which I trimmed down to create a 5PK750
Denso Alternator
#41
Posted 24 October 2011 - 02:52 PM
#42
#43
Posted 24 October 2011 - 03:56 PM
#44
Posted 24 October 2011 - 07:13 PM
H073 5V is the Denso 55Amp version, mostly remanufactured now as they are quite old (from the 1990's)Do you have the part number of this Denso alternator ?
I bought a Kubuta A2198 60Amp version because it was brand new and half price
#45
Posted 24 October 2011 - 07:33 PM
#46
Posted 24 October 2011 - 07:37 PM
#47
Posted 24 October 2011 - 08:02 PM
#48
Posted 24 October 2011 - 08:06 PM
#49
Posted 24 October 2011 - 10:50 PM
#50
Posted 25 October 2011 - 03:09 PM
If you make the correct mounts then it will fit most enginesis there any chance that this alternator works on a Z20LET?
Fitting a Denso alternator is a very common conversion
#51
Posted 25 October 2011 - 03:48 PM
#52
Posted 25 October 2011 - 08:20 PM
#53
Posted 26 October 2011 - 04:04 PM
My conversion is really only for the NA engine, the main aim was to reduce weight and lower the alternator. Thus the tensioner is just a L shaped piece of metal.Can I ask your opinion please??....
This is a nice mod and fairly easy to replicate. I noticed the single pivot point and I would value your opinion on if you feel this is sufficient on a supercharged car that may have a bit more belt tension. Last thing I'd want is the little begger snapping off! (I have the super tight 1270 belt ).
For the SC it would perhaps be better to mount it where the original alternator is mounted and use two brackets to firmly secure it and retain the belt tensioner - just like the original.
Edited by vocky, 26 October 2011 - 04:05 PM.
#54
Posted 26 October 2011 - 04:05 PM
2.2 OEM weighs 6KgHow heavy are the OEM alternators anyone?
Denso weighs 3Kg
#55
Posted 22 February 2013 - 09:29 PM
#56
Posted 22 February 2013 - 09:50 PM
The alternator also needs an additional positive feed to "jolt" it into action.
Dave.
#57
Posted 23 February 2013 - 08:56 AM
Kubota bought Denso, so basically a new ownerWhats the relationship between Denso and Kubota?
#58
Posted 23 February 2013 - 09:11 AM
#59
Posted 23 February 2013 - 09:37 AM
#60
Posted 23 February 2013 - 12:13 PM
I used as in the pictures. I had to fit a 5p pulley, modify the bottom mounting, machine up a spacer and fab an adjuster strap.
Dave.
