Edited by Nev, 08 October 2011 - 02:31 PM.
Posted 08 October 2011 - 02:30 PM
Posted 08 October 2011 - 04:24 PM
Ummm, you can get cam regrinds from Piper that will suit your needs for approx £250. Their 'VXR' regrind adds 1mm of lift to the inlet which will be totally safe for you with the Cometic 1.9mm gasket. In fact, if you have bought Courtenays/PECs (Cosworth) forged pistons with the deeper pockets, you could even ask for 1.5mm to 2mm of extra lift (though these are more expensive as they require blanks to grind from), though you will likely incur a lump idle. If you have bought these pistons you will find it impossible to get exact info about them, I tried on 3 occasions to different people in vain and gave up.
Std valve springs will be fine, so long as you dont rev beyond 7500 RPM (which you turbo wont want to do anyway).
What exhaust + downpipe will your car have? Hopefully 3" at least or you will be bottleneck your exhaust gases and might melt your head/hot side with too much back pressure.
Stage 6 tune?! What is their stage 5 tune?! LOLYou will end up with whatever Klassen pulls out of the bag unless you specify how you want your setup to work. If I were you, when you go there for the map, I would specify that you want as flat a torque line as possible (at the expense of power). Also, take the car out for an extended drive (ie at least 50 miles) before paying and make sure the partial throttle mapping has been done well enough (both at low and high revs).
Posted 09 October 2011 - 05:35 AM
Edited by Nev, 09 October 2011 - 05:39 AM.
Posted 12 October 2011 - 10:54 PM
Posted 13 October 2011 - 07:37 AM
Posted 13 October 2011 - 08:31 AM
Posted 13 October 2011 - 02:41 PM
Posted 13 October 2011 - 03:00 PM
Posted 13 October 2011 - 05:45 PM
Posted 13 October 2011 - 05:48 PM
Posted 13 October 2011 - 06:18 PM
Posted 14 October 2011 - 10:53 AM
Posted 14 October 2011 - 10:54 AM
Posted 15 October 2011 - 02:46 AM
Hi all,
Not to be a bringer of doom or gloom, when I installed my first Z20LEH engine the block let go in a spectacular style. The power output was in the region of 330 bhp and 1.6 bar boost pressure from a 2871rs Garrett. Investigation of the block showed the bore had cracked around the water jacket between cyinders 2 & 3, the wall thicknesses on the LEH have been deliberately reduced compared to a Z20LET block.
Posted 16 October 2011 - 02:55 PM
Posted 16 October 2011 - 03:54 PM
Now had a change of plan again the nortech I have just bought is up for sale and I am now going to get Jay at nortech to me me a new manfold with a vband fitting and external waste gate to try and eliminate as much boost creep as I can. So the new job sheet for Jay is:
New manifold with vband and external waste gate
Supply gtx3071r with vband fitting
Supply tail 38mm external waste gate
Make down pipe and screamer pipe
Make full exhaust system
So then my new rebuild engine should be built around the same time. Still unsure in the cams to go for yet but have bought a set of 875cc injectors to cope with the power so the car will then be mapped to 400bhp with the potential of more if 400 isn't enough
Edited by Nev, 16 October 2011 - 04:00 PM.
Posted 16 October 2011 - 04:06 PM
Edited by craigb78, 16 October 2011 - 04:08 PM.
Posted 16 October 2011 - 04:24 PM
well after speaking to RS Tuning who are the people doing my mapping which are proven mappers by george lockerbys corsa c and speckys tigra, they have told me i will need 875cc injectors for 400 bhp as they will be better than a set of 630s at full capacity. also the GTX3071 is also the turbo of which i was told by rs tuning to go for i also kniow wa guy who is running 330bhp on a astra with 875cc inectors and his car is on a gt3071 not a gtx and he doesnt suffer with any lag what so ever and he was the guy who went to rs tuning too so tbh if worst comes to worst and the injectors and turbo are too big for 400bhp i will then go for 450bhp and deal with the fact i cant get all my power down all the time lol.
and as for the head work i am not doing anything as i think its pointless for the power i want as a standard head has been proven by george lockerby on his corsa to make 488bhp.
also i have now bought a TTV L&B Flywheel.
Edited by Nev, 16 October 2011 - 04:29 PM.
Posted 16 October 2011 - 05:36 PM
Posted 20 October 2011 - 08:57 PM
