Testing The Abs/speed Sensor?
#21
Posted 26 October 2011 - 10:13 AM
#22
Posted 26 October 2011 - 04:50 PM
#23
Posted 26 October 2011 - 05:21 PM
It's a £10 pound part and a lot easier than replacing a hub to find out that's not the issue.
Part number please...
#24
Posted 26 October 2011 - 08:09 PM
#25
Posted 26 October 2011 - 09:16 PM
No part number but this is the one.
http://www.ebay.co.u...f#ht_500wt_1180
Comes from America though. I'm sure I can have a look on the bit when it arrives. TBF I've probably paid more htan I should ordering it from there but it is the only one I can find at the mo that fits.
Hope that helps!
I will have a look at mine and take a photo tomorrow in the light and write the pin out on it. I can't take credit for the details in my post I'm afraid, got them from a question I asked not that long ago.
Edited by sford, 26 October 2011 - 09:18 PM.
#26
Posted 26 October 2011 - 10:59 PM
That would be great thanks a lot!
Hope that helps!
#27
Posted 27 October 2011 - 08:35 AM
#28
Posted 27 October 2011 - 11:27 AM
#29
Posted 27 October 2011 - 12:00 PM
#30
Posted 27 October 2011 - 08:06 PM
You can see PIN one and that runs along the top to pin 15, pin 16 is the bottom right and runs to the middle of the block. The central line is the continuation from 20+ then the bottom left are 27 to 31.
When unplugging this connector, there is a slide next to where the cables plug in that removes it from the abs ecu which the unlabeled arrow points to.
Hope that helps!
#31
Posted 27 October 2011 - 09:09 PM
#32
Posted 27 October 2011 - 10:02 PM
#33
Posted 27 October 2011 - 10:06 PM
#34
Posted 28 October 2011 - 10:37 AM
Hope that helps!
That is just the pug and wires and not the sensor that goes into the hub therefore if a sensor has failed or the wires have broken into the hub, that won't work.
#35
Posted 28 October 2011 - 12:15 PM
Hope that helps!
Apologies, I thought the OP had posted that he tested the wires going into the hub and they all showed the correct resistance, hence why I went on to mention the actual loom as opposed to the sensor itself.
I had found on mine that the wires coming out of the plug itself had gone brittle (presumably due to moisture and general crap) and, if in the instance of the issue I had, broken/failed just higher up from the hub where the wires go through the wheel arch.
Sorry for the confusion.
Edited by sford, 28 October 2011 - 12:15 PM.
#36
Posted 28 October 2011 - 12:32 PM
#37
Posted 29 October 2011 - 10:34 AM
Edited by hutchy, 29 October 2011 - 10:37 AM.
#38
Posted 29 October 2011 - 01:40 PM
#39
Posted 03 July 2012 - 09:58 PM
If you have a multi meter you can read the pons at the abs ecu end. Not sure off the top of my head but if the meter reads 0 (no resistance) then that is the faulty one. Think you should be reading 1.4 ohms??? Resistance ish on them. All you need to do is unplug the wiring loom from the ecu located at the front drivers side wheel. Simply open the front bonnet and it's the black box with Bosch on it. The plug is on the side of this box and has a slider that helps remove it. The pin out is below.
Rear right 9 + 10
Front right 12+ 13
Rear left 22 + 23
Front left 14 + 25
Obviously you know which one is faulty but just be doubley sure that it is a new hub that you need. My abs light is on as the wires coming to the sensor have broken, though they are just old and corroded, making the wires brittle and because of this they have snapped. You can just trim off the section that is brittle and replace it with a new/used gm abs connector pigtail with the correct clip on the end.
It's a £10 pound part and a lot easier than replacing a hub to find out that's not the issue. Where are you located. If not too far happy to meet you around the midlands/bham area to have a quick look!
Tom
Thanks - this was really helpful when I needed to get the VX thru its MOT!
#40
Posted 04 July 2012 - 07:49 AM
