Courtenay "billet Steel 5,6 Kg Flywheel"
#21
Posted 27 June 2004 - 06:18 PM
#22
Posted 27 June 2004 - 06:30 PM
#23
Posted 27 June 2004 - 07:28 PM
#24
Posted 27 June 2004 - 08:13 PM
you´ll need some serious weightwatching with that flywheelPlus I hope that Courtenay have performed at least some testing before releasing the product
..it seems a nice figure 5,6 kg ...."lagom" you know Anders
what does "lagom" mean
#25
Posted 28 June 2004 - 11:05 AM
#26
Posted 28 June 2004 - 03:45 PM
would be interesting to hear what flywheel they´ve been using if it´s not the one they claim.The only unit we have sold in Europe is in Franch and this was the old style remachined unit for the Turbo not the 2.2.
If this was a 2.2, then it is nonsense, and is not ours. This product has only been released for 9 weeks (Madg's supercharged car being the first) and we can acount every unit so far, all of which have been installed in our workshop !!
I think someone may be trying to discredit ours as they have thier own to sell.
#27
Posted 28 June 2004 - 03:53 PM
#28
Posted 28 June 2004 - 09:34 PM
#29
Posted 01 July 2004 - 09:13 AM
They weigh 3.4kg and have a replaceable hardened steel clutch contact surface should you ever wear it down.
They normally retail at £350ish, I managed to get them for £240. Delivery would be either £18.50 special delivery (preferred) or £10 parcel post with extra insurance(£500).
This is one for a c20let engine in a calibra, the only difference to the Z20let one is only 6 flywheel to crank bolts instead of 8
Flywheel picture
#30
Posted 01 July 2004 - 10:33 AM
I checked into this.........I dont know what you were told but the cost of a lightened flywheel is actually £200 not £370.Thought it seemed reasonably priced at £225 compared to the horrific £370 that AmD quoted me!!
And the Courtenay wheel is a brand new item, while AmD just machine the standard one. And the court item is a mere 5,6 kg compared to the 7 kg AmD lump (because they use stronger steel)
I immediately placed an order!!![]()
Are there any drawbacks
AmD have done quite a few stage 3's now and they are working well.
Rubber has one as does Shiny Andy and they seem to like it
#31
Posted 01 July 2004 - 11:45 AM
including fitting perhaps??
#32
Posted 01 July 2004 - 12:00 PM
Edited by clipping_point, 01 July 2004 - 12:01 PM.
#33
Posted 01 July 2004 - 09:08 PM
#34
Posted 06 July 2004 - 11:31 AM
#35
Posted 06 July 2004 - 12:05 PM
that is as much as you can remove from the std fwheel w/out affecting its strength too much, exp if you plan supercharging....And "Pascal" on the speedster forum removed 2,5 kg in a lathe - free!
#36
Posted 15 July 2004 - 10:21 AM
#37
Posted 19 July 2004 - 04:06 PM
#38
Posted 22 July 2004 - 10:25 PM
#39
Posted 23 July 2004 - 08:57 AM
I was spectating when my tuner did this job...Refitting
few pointers:
make sure you use a torque wrench!!!
before refitting, make sure the thckness of the original combo is the same as the new installment, or you will fcuk up the clutch master cylinder!
(opel monkeys did that!
also make sure the new flyw. fits perfectly and there is clearance all around the edge, where the pressure plate moves in and out....
keep it perfectly clean and degreased !!!
bleed the clutch afterward.
have fun!
#40
Posted 23 July 2004 - 09:04 AM
