Low Afr
167 replies to this topic
#101 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 29 January 2012 - 07:30 PM
those error codes up now Joe? was that a new sensor?
Edited by NickB777, 29 January 2012 - 07:34 PM.
#102 The Batman
Posted 29 January 2012 - 07:39 PM
only bloody done 100 miles! those error codes are on op com but eml isnt on it was a new lambda sensor :blink: i have no idea what to do now
#103 Exmantaa
Posted 29 January 2012 - 08:06 PM
So... First clear all error codes to see what is what now. And that screen dump was with a running engine?? I see O2 B1 = 0mv and that is not good. Heater of O2 B1 is OK, so something fishy there. Did you check the wiring of your mixture O2? LET diagram shows pin 25(=3) and 8(=4) are the O2 B1
#104 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 30 January 2012 - 10:39 AM
If the AMM has failed - are you using an oiled air filter (K&N or the like)? If so this could of killed the AMM
#105 The Batman
Posted 30 January 2012 - 01:46 PM
I got a pipecross cone filter brand new one.. :unsure:
#106 JG
JG
  • 13,615 posts
Posted 30 January 2012 - 01:58 PM
i'd go onto a standard airbox.
#107 JG
JG
  • 13,615 posts
Posted 30 January 2012 - 01:59 PM
but it looks like something isn't right on your lambda(s)
#108 The Batman
Posted 30 January 2012 - 02:09 PM
I only have the one lambda which is a bit wierd. I will pm nick and hopefully he is in te country so I can go and compare data with his :)
#109 NickB787
NickB787
  • 7,813 posts
Posted 30 January 2012 - 02:32 PM
pmed Joe I have an Apexi dry cone filter, possible the piper cross has some oil in it which may have killed the Maf I also have the one Lambda but bank 1sensor is working ok not bank 1 sensor 2
Edited by NickB777, 30 January 2012 - 02:35 PM.
#110 Exmantaa
Posted 30 January 2012 - 09:10 PM
Did you look into this further? As Nick said, his 2nd O2 is also 451mv fixed like you have. But your 1st O2 reading is not normal. Lowest a narrowband gets is normally ~20mv for a very lean condition. Your 0mv shows a loose connection or so. Check the wiring to the ecu pins.
#111 alanoo
alanoo
  • 1,324 posts
Posted 30 January 2012 - 09:28 PM
Hum lowest any sensor would read will be 100 or 500 mv, the amount below is here for diag, so 0 mV is definitely a not working sensor (or connection)
#112 Exmantaa
Posted 30 January 2012 - 10:25 PM
A pic for clarification, and as Alanoo already said the extremes are for diagnostic purpose. 0mv is not a normal O2 signal, so sort that.
#113 The Batman
Just speaking to vocky reckon I might need a vxt lambda sensor so will get one of them ordered
#114 Exmantaa
Posted 30 January 2012 - 10:30 PM
??? What''s the difference? Thought you changed it out already. Did you check the wiring?
#115 The Batman
Posted 30 January 2012 - 10:38 PM
I put a new z22se one in so going to try a z20 one now I'm double shifting all week aswell as staying away from home so not sure when I can swap them over. Hopefully grab an hour on Wednesday/Thursday and just sacrifice a bit of sleep :blink:
#116 techieboy
Posted 30 January 2012 - 11:03 PM
Nick's is definitely a VXT lambda sensor. He was most disgruntled when Courtenay's changed it over.
#117 The Batman
Posted 30 January 2012 - 11:06 PM
Ah ha! Another piece of the puzzle uncovered
#118 Exmantaa
Posted 30 January 2012 - 11:33 PM
O2 sensor should be similar, but is the VXT's pin layout different in the quad connector???
#119 VIX
VIX
  • 9,497 posts
Posted 30 January 2012 - 11:44 PM
Synchromesh gone? :rolleyes:
#120 The Batman
Posted 31 January 2012 - 12:31 AM
:lol:
