Info About Eibach Springs
67 replies to this topic
#61 cicastol
cicastol
  • 423 posts
Posted 17 August 2004 - 09:44 AM
Thanks for the update thumbsup Did you have any problems with the suspension hitting the bumpstops?
No, until now i 've not experienced any bumpstop hit, roads here are quite smooth and i'm very careful on bumby roads ;)
Remember that this fcuking front springs are progressive,initial compression is softer than original, but suddenly the compression rate increase really high make the spring hard enough to confuse with a bumpstop hit.
Cheers
P.S. I've found on lotus service manual that the uprated springs supplied with sport damper set are progressive on front.
Front: from original 27.5 N\mm to 25-40 N\mm dual rate
Rear: from 40 N\mm to 50 N\mm
This rates seems like the eibach solution!!
Edited by cicastol, 17 August 2004 - 09:58 AM.
#62 iandhd
iandhd
  • 3,756 posts
Posted 22 March 2005 - 12:42 PM
How many people do we have on the site with the lowered Eibach's fitted to an n/a? How are you finding them?
#63 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 22 March 2005 - 01:39 PM
Goofballs tried them, but took them off...
#64 clipping_point
clipping_point
  • 4,908 posts
Posted 22 March 2005 - 06:49 PM
I had them for 1-2 years. Slightly softer fronts which could give less understeer and better balance. Better comfort as well. The car looks much better with them thumbsup The fronts are progressive, which may or may not be mistaken for a bump stop. Tried them, liked them, but there are drawbacks.
#65 iandhd
iandhd
  • 3,756 posts
Posted 23 March 2005 - 07:42 AM
What have you got now CP?
#66 clipping_point
clipping_point
  • 4,908 posts
Posted 23 March 2005 - 08:00 AM
I bought Nitrons since I do a lot of trackdays. I thought there was too much body roll, so I wanted to stiffen the car a bit. May buy the adjustable ARB from plans later, as well :rolleyes:
#67 snoopstah
snoopstah
  • 3,056 posts
Posted 23 March 2005 - 08:34 AM
Drawbacks compared to the OE suspension, or compared to a complete suspension kit (Nitrons/Ohlins)?
#68 clipping_point
clipping_point
  • 4,908 posts
Posted 23 March 2005 - 11:23 AM
The drawback was, compared to the OE ones, that because the front springs were softer I suspected that the body roll was greater. Another thing was that, since they were progressive, u had that harsh bump stop feel on B-roads. But its no big deal; the car certainly looks better and the ride is more comfortable. thumbsup
