Sc Manifold Redesign
Posted 05 July 2012 - 02:13 PM
Posted 05 July 2012 - 06:28 PM
Posted 05 July 2012 - 08:20 PM
Posted 05 July 2012 - 08:21 PM
Posted 05 July 2012 - 08:33 PM
Posted 05 July 2012 - 09:44 PM
Posted 21 December 2012 - 03:00 PM
Looks about M62/TVS-1320 sized and the bolt hole positions on the inlet flange look Ecotec'ish.
Posted 21 December 2012 - 03:27 PM
Edited by Exmantaa, 21 December 2012 - 03:30 PM.
Posted 21 December 2012 - 03:32 PM
Posted 21 December 2012 - 03:45 PM
Apparently this was fitted into a Speedster/VX220, but that would be a very tight squeeze...
You can just see the oil filter here that he had to work around. If you relocate that this would be very feasible.
400HP TVS and a lower CoG?
Posted 21 December 2012 - 03:48 PM
Posted 21 December 2012 - 03:51 PM
Posted 21 December 2012 - 03:52 PM
M90 is my plan but with a shorter snout
That's also key. So many different snout options out there and also the throttle body endplate end as well.
Posted 21 December 2012 - 04:03 PM
M90 is my plan but with a shorter snout and mounted at sump level. Need to mock up first but I was planning on the plenum being the mount (new casting) and feeding into a saab turbo manifold via a tubby CC system. Just bidding on an M90 on fleabay now.
The M90 is an even older design than our M62's that do not handle boostpressure well. Cheap, but for all the trouble I would go TVS.
(ps.; if you want out-of-the box thinking, look maybe into a Mazda Millenia charger?)
But I just found a very good reason to plan some butchery on an empty engine casing I happen to have standing here.
Posted 21 December 2012 - 04:27 PM
I got an engine stand you can borrow MattIf ever there was a case for a remote oil filter, that engine and SC combo is it. :wacko:/>
M90's are sooo cheap, just rare to find one of the generation V versions. :(/>
Bugger. That picture has also reminded me I wanted to order an engine stand for use over Christmas. :beat:/>
Posted 21 December 2012 - 05:16 PM
Posted 21 December 2012 - 05:18 PM
Posted 21 December 2012 - 05:21 PM
Thanks Lee. What you need to bear in mind is that it's me we're talking about. So, based on the fact the engine has been sat in the garage for 18 months without me touching it (apart from whipping the tensioner out for Jimmy's Cadwell TA adventure), it might not be the quickest turnaround you've ever seen.
Posted 21 December 2012 - 05:27 PM
Joe tried. They didn't fancy it.
Oh, has anyone tried Dave Hardwick? He's very capable.
