Losing The Will To Live
#41
Posted 15 September 2012 - 09:37 PM
#42
Posted 15 September 2012 - 10:15 PM
#43
Posted 16 September 2012 - 07:35 AM
#44
Posted 16 September 2012 - 07:40 AM
#45
Posted 16 September 2012 - 07:45 AM
Edited by vocky, 16 September 2012 - 07:45 AM.
#46
#47
Posted 16 September 2012 - 07:46 AM
#48
Posted 16 September 2012 - 08:17 AM
Neil,
Seriously... A bullet point list of things, rather than looking through.
1. Changed coil packs - no change Check
2. Cleaned contacts with ? Electrical contact cleaner
3. Egr hole covered. Egr cheater not fitted, valve?
4. Blue plugs of doom.
5. ECU connectors cleaned.
Yep your right sorry.
Edited by Baron Von Scubadaddy, 16 September 2012 - 08:19 AM.
#49
Posted 16 September 2012 - 08:23 AM
#50
Posted 16 September 2012 - 08:26 AM
#51
Posted 16 September 2012 - 08:32 AM
Any error codes in ecu? (Scanguage or other obd2 reader)
Lambda sensors?
I have EML on but have no reader
My Piper has always caused the eml to come on I have a sim but have yet to fit it as I am scared about mounting it incorectly as it has some chunky resistors in it also I can't remember where it plugs in ( I have terrible short term memory loss something to do with too many parties back in the day
#52
Posted 16 September 2012 - 08:34 AM
#53
Check taht the two plugs are pushed fully home. The last few mm are tough but critical. Make sure the latches click home too.
It could be loose connectors in the plug too. If you open the plug, look in, pull off the yellow mesh to expose the terminals. Look very carefully and you'll see a spring part inside them. This can get bent back if the terminal is weak. This is caused by the wiring moving either side of the plug (anchor the wires!!!). You can bend them back with a pin as a get you by measure whilst you get some new terminals. Fingers crossed for you. Took me 3 months to pin down the terminals as faulty in mine.
Next on my list of to do's
Gotta get the 12 year old across london to a footie match in deepest darkest surrey in a min so will be in workshop mode when I return in a few hours
#54
Posted 16 September 2012 - 08:37 AM
I can send you my scanguage if you cover a bit for postage. Or collect from NW8?
Pal
you is just round the corner from me
Could I pop round on the way back from Bandstead ?
I'm in N19
Thanks for the offer
#55
Posted 16 September 2012 - 08:42 AM
Pal
I'm in N19
NW8 Monday to Friday that is, should have made that clear. Today is E14.
#56
Posted 16 September 2012 - 08:51 AM
#57
Posted 16 September 2012 - 09:11 AM
#58
Just a wild stab in the dark here but mine is having similar issues and it seems to be a power drain. lastnight i had the lights on and the radio and the misfire was bad with the car cutting out when i hit the revs but then improved when i removed turned off the radio after 20mins of driving restarting whislt moving the car came back to life, so im now thinking Battery !
That sounds like the connections are loose and slipping under accleration, check connections are tight and not hitting anything in the bonnet
#59
Posted 16 September 2012 - 09:20 AM
#60
Posted 16 September 2012 - 10:11 AM
