![Photo](http://www.vx220.org.uk/forums/uploads/profile/photo-thumb-274.jpeg?_r=1447861116)
Help Please
#81
Posted 07 October 2012 - 06:58 AM
#82
Posted 07 October 2012 - 08:01 AM
#83
Posted 07 October 2012 - 09:16 AM
#84
Posted 07 October 2012 - 09:21 AM
#85
Posted 07 October 2012 - 09:29 AM
Edited by NickB777, 07 October 2012 - 09:29 AM.
#86
Posted 07 October 2012 - 09:58 AM
![:lol:](http://www.vx220.org.uk/forums/public/style_emoticons/default/laugh.png)
![thumbsdown](http://www.vx220.org.uk/forums/public/style_emoticons/default/thumbsdowngraemlin.gif)
Edited by vocky, 07 October 2012 - 09:58 AM.
#87
Posted 07 October 2012 - 11:19 AM
fuel pump relay isn't switching by the sound of it,
was the 'red' wire I added for the CC pump or the fuel pump relay ?
either way check the relay for the fuel pump(s) and the relay in the boot
red was for the cc relay
#88
Posted 07 October 2012 - 11:30 AM
#89
Posted 07 October 2012 - 12:02 PM
#90
Posted 07 October 2012 - 12:23 PM
#91
Posted 07 October 2012 - 12:34 PM
#92
Posted 07 October 2012 - 12:41 PM
#93
Posted 07 October 2012 - 12:42 PM
![:unsure:](http://www.vx220.org.uk/forums/public/style_emoticons/default/unsure.png)
#94
Posted 07 October 2012 - 01:08 PM
I was just toping it upmight be time for a new battery if it's lost it's charge that quick
so confirmed no power to the secondary pump
#95
Posted 07 October 2012 - 01:22 PM
does the engine crank over ?
does the eml flash ?
It cranks over,
no eml flashing,
so JUST got to sort the power to the secondary pump
Just conform Neil that was right the red wire goes to the secondary fuel pump relay?
I also have a black wire from K16(brown and green to the cc pump)
Edited by NickB777, 07 October 2012 - 01:25 PM.
#96
Posted 07 October 2012 - 02:00 PM
Everything you should know: http://www.speedster...e Z22SE - 1.pdf
Z22SE ecu feeds the pump relay with a 12v signal:
White violet wire from ecu through pin 8 of the X2 connctor to connection 2 of the fuel pump relay. Relay pin 4 is to ground.
LET is different, as the ecu switches to ground: http://www.speedster... Z20LET - 2.pdf
(Relay pin 4 switched to ground through X2-8, Wh-Vt wire. Relay pin 2 has +12v through K18.)
here is what I have
K16 back - wht/vt (large cable) +12v
k18 small brown +12v green/pink -
Edited by NickB777, 07 October 2012 - 02:00 PM.
#97
Posted 07 October 2012 - 02:14 PM
#98
Posted 07 October 2012 - 02:28 PM
K16 black - wht/vt (large cable) +12v => that's the +12v feed, OK. Thin Wh/Vt from ecu gives +12v when cranked? If yes, does the K16 switch and give power to the BnGy wire ? (you can bridge the relay with a +12v to the thin Wh/Vt to check working...)
k18 small brown +12v green/pink - => That means the ecu gives a correct ground signal with the Green/Pink. Does the K18 give now power to the Bn and Bn/Pk wires?
First part yes
when cranking no power from the Bn(2) and Bn/pk(2)
Edited by NickB777, 07 October 2012 - 02:38 PM.
#99
Posted 07 October 2012 - 03:03 PM
#100
Posted 07 October 2012 - 03:21 PM
