Project Rabiata
119 replies to this topic
#21 JG
JG
  • 13,617 posts
Posted 17 November 2012 - 08:02 PM
meh, its probably worst from here. No one lives north of the watford gap, so at least he won't have traffic.
#22 forgotmepassword
forgotmepassword
  • 1,120 posts
Posted 17 November 2012 - 08:13 PM
Looks ace.
#23 nicollow
nicollow
  • 3,801 posts
Posted 18 November 2012 - 09:59 AM
Awesome stuff sir :)
Did you find it pretty straight forward? Any major issues?
The suspension swap was very straight forward, supercharging less so :P To be fiar, it all went together pretty easily, with no major headaches. Could probably do it in half the time now and didnt have any help, just plugged away and it soon all comes together. ;)
It'll get mapped in January at the earliest. Ive got to go down for a conference then and dont have the time before that, given its about an 8000 mile drive...
#24 Rally
Rally
  • 650 posts
Posted 18 November 2012 - 11:01 AM
Nic, where's that vacuum pipe going? If it's not attached to the servo, where is the servo getting vacuum from?
#25 CocoPops
CocoPops
  • 17,182 posts
Posted 18 November 2012 - 11:06 AM
Oh yeah, does look a little odd. Where is the one way valve also?
#26 CocoPops
CocoPops
  • 17,182 posts
Posted 18 November 2012 - 11:09 AM
Actually it looks like the breather pipe and vacuum pipe are the wrong way round.....
#27 smiley
Posted 18 November 2012 - 11:44 AM
Breather pipe seems to be going to the catchtank/filter next to the header tank. Vacuum pipe routing is interesting though. Gorgeous work on the injector loom part. That looks so oem :wub:
Edited by smiley, 18 November 2012 - 11:46 AM.
#28 nicollow
nicollow
  • 3,801 posts
Posted 18 November 2012 - 12:40 PM
I connected the vacuum line and one way valve up to the throttle body, the hose thats going off to the right is the fuel vent... Thought it would make for neater routing, still need to tidy it a bit more. Seems to work grand, would it be better to stick the vacuum line onto the SC itself and not the throttle body? The breather pipe is routed to a small catch tank. Fills up with condensate pretty quickly. Ive read that thats normal?
#29 smiley
Posted 18 November 2012 - 01:30 PM
You created an entry point just before the TB for that, as i fail to see the TB itself having a connector for it?
Edited by smiley, 18 November 2012 - 01:32 PM.
#30 nicollow
nicollow
  • 3,801 posts
Posted 18 November 2012 - 01:35 PM
Its the brass connector on the RHS that I used...
#31 CocoPops
CocoPops
  • 17,182 posts
Posted 18 November 2012 - 02:21 PM
The brass connector on the tb is for something else. Can't remember what tho :lol:
#32 smiley
Posted 18 November 2012 - 02:31 PM
That connector is on the lsj 68mm only. Capped off on mine. If your braking works fine, i guess it works though. As for hose routing; swapping brake vacuum and fuel vent would look a bit better i think.
#33 nicollow
nicollow
  • 3,801 posts
Posted 18 November 2012 - 02:51 PM
Yeah, probo right... Still got a few odd jobs to do, like solder in the EGR cheater, so will check it all over next weekend ;)
#34 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
He doesn't use his brakes.
#35 JG
JG
  • 13,617 posts
Posted 18 November 2012 - 02:53 PM
Ah yes, thats not quite right. SC vaccum goes to servo with a one way valve. TB goes to charchoal canister thing (fuel vent).
#36 JG
JG
  • 13,617 posts
Posted 18 November 2012 - 03:05 PM
btw CS blank the TB, which isn't quite as nice as the above.
#37 CocoPops
CocoPops
  • 17,182 posts
Posted 18 November 2012 - 03:10 PM
I would assume that the brass inlet on the tb is pre butterfly, thus never has a vacuum? Where as the sc vacuum inlet is post butterfly, so when you let off the accelerator it generates a vacuum.
#38 Rally
Rally
  • 650 posts
Posted 18 November 2012 - 05:28 PM
:yeahthat:
#39 nicollow
nicollow
  • 3,801 posts
Posted 12 January 2013 - 07:57 PM
So Ive painted the hardop now and managed to get hold of an OEM spoiler. Lookin a bit sharper ;) I sprayed a set of tubby ears whilst I was at it, but still in two minds about whether to stick em on or not!!
Got a new daily driver too... :P
#40 CHILL Gone DUTCH
Posted 12 January 2013 - 07:59 PM
dont do the ears it looks a lot sleeker
