Apexi Induction
114 replies to this topic
#1 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 08 February 2013 - 12:53 PM
Hi Guys, I cannot justify spending £1500 on a funky exhaust system - but would like to get more induction noise from the Z20LET.... Having read several threads about the Apexi unit it looks like this may be my perfect answer... I was thinking about just replacing the airbox with the Apexi for now on standard OEM air inlets (63MM?) and maybe switch to 80mm at a later date. Do you think it will sound much better than my current MMG fettled OEM air box? Is it worth it? Can I easily upgrade inlet pipes later and AMM? Does anyone know where I can get a cheap and genuine Apexi unit as most on e-bay seem to be made in Australia and look dodgy? Id appreciate your advice on this. Thanks Jon
#2 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 08 February 2013 - 12:57 PM
There are genuine a'pexi products on ebay. i bought mine from there, the 65mm and it fit's perfectly. If you go to the 80mm setup you will need your map fettling.
#3 Bumblebee
Bumblebee
  • 7,592 posts
Posted 08 February 2013 - 01:13 PM
Amberperformance from eBay for genuine apexi filters. I had my airbox drilled previously and Id say there's certainly a difference,so worthwhile IMO
#4 turbo boy
turbo boy
  • 1,161 posts
Posted 08 February 2013 - 01:20 PM
Thanks Amy / Tim. Tim, how did you fit yours? Did you keep the existing air box / half? Use some kind of a support bracket? Id be interested in the sound difference keeping the OEM fitment? I know Amy has gone for a stage 4 80mm - I cant afford this right now. Cheers, Jon
#5 VXT Tim
VXT Tim
  • 11,421 posts
Posted 08 February 2013 - 01:33 PM
Got rid of all the old gubbings and brackets, you couldn't house the filter in the oe box. Fathomed a new bracket (stolen from an old secuity light in my shed that fitted perfectly) hooked up a cold air feed and that's it. Very simple.
Edited by VXT Tim, 08 February 2013 - 01:38 PM.
#6 VXT Tim
VXT Tim
  • 11,421 posts
Posted 08 February 2013 - 01:37 PM
As for the 80mm amm, my understanding is unless you are going for a lot of power (360+ i read on here) the only real benefit of the 80mm is its more robust. The pipework immediately after the amm reduces anyway on the 80mm.
#7 astravxr
astravxr
    Straight roads are for fast cars, turns are for fast drivers
  • 1,748 posts
Posted 09 February 2013 - 12:59 PM
If you got the apexi 65mm and then later on got the 80mm amm wouldn't you need to buy a new apexi to fit?
#8 VXT Tim
VXT Tim
  • 11,421 posts
Posted 09 February 2013 - 01:39 PM
You would need a new adapter plate, not a new filter I believe.
#9 denno
denno
  • 1,528 posts
Posted 09 February 2013 - 02:12 PM
So does a stage 4 need an 80mm air mass meter or not? And if so could an 80mm apexi filter be fitted at a later date without needing the map tweaking? The ones on eBay say universal fitting, are they the ones?
#10 redvts
redvts
  • 1,472 posts
Posted 09 February 2013 - 03:53 PM
Stage 4 uses 80mm maf sensor
#11 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 09 February 2013 - 04:05 PM
As far as I know stage 4 doesn't need a 80mm air mass meter. It helps though!
#12 turbo boy
turbo boy
  • 1,161 posts
Posted 09 February 2013 - 05:26 PM
Nice one. Thanks for your advice Tim
#13 P11 COV
P11 COV
  • 7,686 posts
Posted 09 February 2013 - 05:29 PM
Doesn't need one but the standard maf does have a habit of failing.
#14 astravxr
astravxr
  • 1,748 posts
Posted 11 February 2013 - 02:29 AM
So what's the difference between the apexi and a ripspeed cone filter? http://www.halfords....65660&langId=-1 I guess its just the name your paying for? Also will the ripspeed work just like the apexi does?
#15 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 11 February 2013 - 05:53 AM
Is this a serious question?
#16 Dashwood
Dashwood
  • 494 posts
  • Interests:discussion
Posted 11 February 2013 - 07:29 AM
If you want a bit more noise from the exhaust you could always do the Pipo mod http://www.vx220.org...andard-backbox/
#17 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 11 February 2013 - 07:51 AM
:yeahthat: :blink:
#18 astravxr
astravxr
  • 1,748 posts
Posted 11 February 2013 - 08:27 AM
Yep
#19 hughcam
hughcam
  • 730 posts
  • Interests:driving, motorcycling, snowboarding, v12 lawn mowers
Posted 11 February 2013 - 08:46 AM
The main difference (I would assume) is that the quality of the filtration will be better on the Apex I kit. I.E it wont fcuk the engine of your expensive car...
#20 astravxr
astravxr
  • 1,748 posts
Posted 11 February 2013 - 08:55 AM
Yeah I thought that but wasn't sure if the ripspeed would be just as good with a rubbish name
