Project Snow White
448 replies to this topic
#221 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 May 2013 - 05:14 PM
P1614 Loss if rim serial data?
#222 vocky
Posted 29 May 2013 - 06:22 PM
you must remove the key chips from the white cars keys and then fit the black cars key chips into the white cars keys, otherwise the ecu will throw a wobbly with two different key chips present.
:poke:
#223 CocoPops
CocoPops
  • 17,182 posts
Posted 29 May 2013 - 06:31 PM
You can lead a horse to water Neil :lol:
#224 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 May 2013 - 07:44 PM
:poke:
I have done that, ECU, Transponder and chip all match.
I push the started button and nothing happens.. I might have disterbed something putting the transponder in so I take that to bits again and give it a look
#225 J4EY D
J4EY D
  • 3,236 posts
Posted 29 May 2013 - 07:50 PM
I wonder if having the 2 key chips there on the first attempt has tripped something?
Have you got Mr Captain's opcom there?
#226 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 May 2013 - 07:58 PM
not got Capitans laptop.
On the first attempt, I just had the old transponder hanging down and the old key pressed against it. the white Key was in the ignition (the the transponder unplugged).. the VX started, slowly but did start. after it was running for a few seconds I turned it off to check water levels. All was good so I went to restart it and it just clicked.. nothing happened :huh:
#227 2deano5
2deano5
  • 668 posts
  • Interests:Cars / Squash
Posted 29 May 2013 - 08:00 PM
Give it a charge stuwy if it started slowly it could be the battery, rules one thing out, these things are always a process of elimination. Deal with thee easy things first :)
#228 Roastie ITR
Roastie ITR
  • 365 posts
Posted 29 May 2013 - 08:05 PM
Spotted a white VX going along the M25 between the A127 and A13 and thought that you had it all up and running. Sounds like your not too far off though.
#229 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 29 May 2013 - 08:12 PM
You manage to get the stuff off the black one then? Excellent. Sounds like a battery, any of your neighbours have some jump leads?
#230 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 May 2013 - 08:49 PM
Will get some leads on it tomorrow and report back
#231 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 29 May 2013 - 09:08 PM
Golly.
I've changed 2 screens...not a fun or easy job.
I also did some of this ECU business.
i bought an Astra matched set....sent the ECU to CS for a basemap.
Chips into my old keys and bob was my auntie.
(Then I sold my old ECU+NA mapping)
#232 smiley
Posted 29 May 2013 - 09:16 PM
1614 is key not recognised by ecu.
Get your opcom buddy back in to verify.
#233 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 29 May 2013 - 09:18 PM
Will this never end? :lol:
#234 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 May 2013 - 09:51 PM
I fcuking hope so
#235 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 May 2013 - 09:52 PM
I hoping its an old code as I have the correct chip+transponder+ECU, and the battery  is just playing silly fuckers
#236 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 29 May 2013 - 09:56 PM
they were being "helpful" with settlement so I negotiated something that would save me 400 instead
#237 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 30 May 2013 - 06:43 PM
Battery is fine. Any ideas?
#238 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 30 May 2013 - 07:04 PM
Code cleared and not re-appeared. Fuses look fine
#239 Zoobeef
Zoobeef
  • 11,103 posts
Posted 30 May 2013 - 07:10 PM
Does the starter relay click when you press the button? Does power get down to the motor? Is the motor stuck? Take the chip out the white key and keep away from the car.
#240 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 30 May 2013 - 07:12 PM
It's alive!!!!!!
