Coupe'd
89 replies to this topic
#21 FLD
Posted 17 February 2014 - 04:12 PM
shape and then coat with a layer of filler
then a layer of grp and fill and sand and then it should be next christmas and I will have more time to finish it off !!!
I'd suggest this for filling the surface in the foam
http://www.easycompo...oat-primer.aspx
and then this for the glossy top coat
http://www.easycompo...t-hi-gloss.aspx
You should be able to get similar stuff for cheaper from somewhere like eastcoast but the easy composites stuff is top notch quality.  It will also be easier than adding grp to the foam too.  Have a watch of their you tube tutorial.
#22 Baron Von Scubadaddy
  • 6,645 posts
Posted 17 February 2014 - 04:14 PM
Mate I've been watching all their films !!!!
Thanks for the links to those bits
Thats the way I'll go
#23 Baron Von Scubadaddy
  • 6,645 posts
Posted 17 February 2014 - 04:36 PM
Anyone know if carbon sheets come in width bigger than 1.25m ?????
found some american stuff thats 50"
I like to use just one peice to make the coupe
otherwise have i got to start funkin about trying to get the weave to match along a join ??
#24 TazN
TazN
  • 2,931 posts
Posted 17 February 2014 - 04:42 PM
http://www.easycompo...m-3k-150cm.aspx
1.5m width.
Are you wanting the cf finish? If not and your painting over then trying to line weave up isn't important.
#25 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 17 February 2014 - 04:45 PM
will be good to see the step by step photos of this in the making.
Top Lad for giving it a go  thumbsup
#26 Baron Von Scubadaddy
  • 6,645 posts
Posted 17 February 2014 - 04:47 PM
I was thinking the whole point of the carbon stuff is to see it
so painting it would be a shame to do as all the hard work goes into making a tool
that gives a great finish
#27 Baron Von Scubadaddy
  • 6,645 posts
Posted 17 February 2014 - 04:51 PM
No work friday so this could be my next chance to take the blade to it
I'm tempted to go back up there and have a play but i know it's still soft and not cured yet
I want it to cure properly so I can lift it off the car and have it remain in shape and not sag.
I've have been toying with the idea of doing this for ages
I just bothered to have a go today !
hopefully I'll be able to get a good mold offof the tool I make
It will also have the roll bar cover built into it and I hope will be a
replacement for the roll bar cover
Edited by Baron Von Scubadaddy, 17 February 2014 - 04:52 PM.
#28 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 17 February 2014 - 07:24 PM
East Coast do Durabuild that can be used as an all in one pattern coat. Might work out cheaper than having to buy primer and gloss.
Bit of a premium on 1.5m cloth over 1m unless you are going for bare carbon. Have a look at the clearance section at east coast, picked up some end of roll and off cuts in both carbon and glass just last week for about 25% saving if the size suits you.
Busy doing an engine cover for the VAG engine at the min myself.
#29 Baron Von Scubadaddy
  • 6,645 posts
Posted 17 February 2014 - 07:43 PM
how are you doing the engine cover
it has a tube on it doesn't it
are you making a 2 part mold for this ????
I can't get my head round it !
#30 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 17 February 2014 - 08:15 PM
Molest A4 cover to suit, smooth it out then take a mold. Not worried about underside not being smooth so only 1 part mold needed. Will stop before pipe and simple flat sheet more or less will bolt to original heat shield fixings.
#31 wbanixon
wbanixon
  • 267 posts
  • Interests:cars, track days, car events, football, music etc...
Posted 18 February 2014 - 12:37 AM
interested to see how this turns out. fair play for taking this on!
#32 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 19 February 2014 - 08:17 PM
Do you have any picture for inspiration or something to show what your aiming at? I found a coupe back 3d on the net which I like and want to do.
#33 Baron Von Scubadaddy
  • 6,645 posts
Posted 19 February 2014 - 09:49 PM
it's all in the mind ..........
but I have tried this before with poly sheets
#34 Baron Von Scubadaddy
  • 6,645 posts
Posted 22 February 2014 - 09:51 AM
Off to the garage with my carving knife .........
#35 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 22 February 2014 - 10:59 AM
Pics ffs :lol:
#36 Baron Von Scubadaddy
  • 6,645 posts
Posted 22 February 2014 - 12:24 PM
Stand by .......
#37 jules_s
jules_s
  • 15,275 posts
Posted 22 February 2014 - 12:39 PM
/taps foot
#38 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 22 February 2014 - 12:41 PM
:tumble:  now been more than 30 seconds !
#39 Baron Von Scubadaddy
  • 6,645 posts
Posted 22 February 2014 - 04:17 PM
got scared and went to the pub for a hoegarden or 3 !
Spray foam is quite sh*t it has quite a few holes inside it and will need a fair bit of work
I had a quick trim of one side
but need to go up there again armed with pens and string and other such stuff to get the profile right
good news is .... it lifted off in one peice without sticking to the car and leaving any residue !
Asking for a vacum baging kit for my birthday in May so I hopefully will have some kid of result by june
or july
or maybe next january when I'm off work and bored again !!!!
#40 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 22 February 2014 - 04:24 PM
Is a hoegarden like a beergarden?
