Can You Test An Actuator?
#21
Posted 19 June 2014 - 07:23 PM
#22
Posted 20 June 2014 - 05:06 AM
Edited by Dave E, 20 June 2014 - 05:08 AM.
#23
Posted 20 June 2014 - 06:35 AM
Sorry if this a stupid thought but could the pre loading of the actuator be a contributing factor.
with no preload my car would hardly boost at all.
#24
Posted 20 June 2014 - 11:04 AM
No overly read the last few posts so sorry if it duplicates
In basic terms and no ecu control of boost the turbo would allow the boost to build to the load of the actiuator at which point it vents directly into the exhaust.
If there is too little or wastegate not shutting fully you will be driving what feels like a n/a (slow Vx ) with the preload set correctly and the wastegate penny opening and closing freely it will drive and boost fine but will not be overly fast - if you have a boost guage you can see the level build and hold a lower reading (7psi iirc)
The ECU using the boost solinoid applies more pressure to the wastegate stopping it opening at the preload value (7psi for example) which is taken from the compressor housing and will have a requested boost target (12psi for example). At this level it will then vent excess boost opening / shutting wastegate.
The ECU will then constantly adjust this based on actual boost v's target. Venting the boost through the solinoid (into intake of turbo housing) when no more boost required. It also works with the recirc for when closing the throttle (changing gear) if dumps the compressed air back inot the intake.
If there is too much preload and or the wastegate penny does not have enough travel to open you will overboost for obvious reasons - this can be seen on a boost guage if fitted. The solinoid controlled by the ECU will try to vent all the boost to try and reduce through wategate but the basic mech setup of actuator / wategate are still boss when not operating correctly
The Z20LET is like most other older turbo cars and same rules apply
The newer stuff gets a lot more fancy using the recir to also regulate boost with the wastegate to get better response and ad to the fun when it plays up
Hope this helps a bit in basic terms, typing on phone is a mission lol
Run with solinoid unplugged - does it perform ok?
Check wastegate movement (un do actuator bolts to allow the threaded bar to move freely)
Check vac setup for ANY leaks inc vac storage box
Check for any boost leaks
Set preload if all ok
Poss replace recirc if required
Beyond this some datalogging would be really usefull to see what the ECU is doing during the issue
DG
#25
Posted 20 June 2014 - 11:27 AM
Would it be at all plausable to use the ECU control line that runs the boost solenoid to directly control an electronic actuator?
#26
Posted 20 June 2014 - 11:42 AM
I have no expriance of electronic actuators on the hot side. I have only messed about with the recirc electronic actuators on the tfsi lump tbh
Guess the signal from ECU would need reviewing to see what it is and how if functions. Then see what electronic actuator is suitable to mounting to turbo and what signal that would like to function correctly
I think its one for you to go and play with slindborg but no reason for it not to work, in fact be interesting to see how it performed
DG
Edited by Duncan VXR, 20 June 2014 - 11:50 AM.
#27
Posted 20 June 2014 - 11:46 AM
back when I worked at Staefa Control System, we used a 0-10v and a transducer to 0-24vac and phase cut for modulating end devices (valves & dampers).
maybe there is something in the moog catalog
#28
Posted 20 June 2014 - 12:44 PM
could use a VGT actuator with suitable rod etc to make it fit the K04.
It can join the queue of other electronics I've yet to get round to
#29
Posted 20 June 2014 - 02:43 PM
#30
Posted 20 June 2014 - 02:55 PM
if the remaining actuator stroke length was too short to allow the w/g to open wide enough , then you would see boost creep at higher rpm , I think most of us see 18psi held and tailing off as normal.
#31
Posted 20 June 2014 - 08:25 PM
I seem to be getting spot on 20 at the moment - too much?
#32
Posted 06 July 2014 - 04:36 AM
Think I might of found my problem
Edited by Dave E, 06 July 2014 - 04:37 AM.
#33
Posted 06 July 2014 - 04:50 AM
#34
Posted 06 July 2014 - 04:56 AM
Edited by Dave E, 06 July 2014 - 04:57 AM.
#35
Posted 06 July 2014 - 06:13 AM
Sure I can see eyes and a face in that
#36
Posted 06 July 2014 - 06:44 AM
#38
Posted 06 July 2014 - 07:31 AM
#39
Posted 06 July 2014 - 08:08 AM
#40
Posted 06 July 2014 - 08:11 AM
Jeez - amazed you got any boost at all with that!
