Misfire Problem - Stage 2 Turbo With Vxr Turbo
71 replies to this topic
#1 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 17 August 2014 - 10:05 AM
Bit stumped with this one like.
Since having my VXR turbo fitted I've been having some problems. First of all was the AMM, which was replaced. Then it was the boost solenoid so that was replaced. I've changed the coil pack and plugs and I'm still having some problems with misfiring under hard acceleration. It's got a Pipercross cone filter on it attached to some uprated piping to the throttle body, and there are no air leaks.
I've searched and repaired where I can find anything remotely close to a misfire problem but to no avail. I now seek some assistance from the .org people...
#2 CocoPops
CocoPops
  • 17,182 posts
Posted 17 August 2014 - 11:34 AM
I thought the amm blows with anything other than a paper filter?
#3 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 17 August 2014 - 11:56 AM
That's what I was thinking. I've changed everything other than the filter, so my thoughts were it could be that.
Fucksake.
#4 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 17 August 2014 - 06:53 PM
What about the wiring and plug to the coil pack?
#5 Ormes
Ormes
  • 4,612 posts
Posted 17 August 2014 - 07:31 PM
Plugs not gapped correctly...?
#6 P11 COV
P11 COV
  • 7,686 posts
Posted 18 August 2014 - 07:49 AM
Yes, cone filters not recommended in the turbo. Can blow the AMM. Not necessarily going to cause the misfiring though. Might be worth a try though.
The standard filter box with some extra holes is fine for 300bhp so I would suggest theres no need for a cone. Also, isn't a cone filter going to pick up lots of warm air form the engine bay anyway so probably worse than the standard box.
#7 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 18 August 2014 - 07:07 PM
I'm gonna give the standard airbox a go and see how that fares, and report back.
Failing that, it must be the plugs. There's nowt left it could be!
#8 SteveA
SteveA
  • 9,157 posts
Posted 19 August 2014 - 08:41 AM
In my experience a dead MAF doesn't misfire, it gives you massive gaps in power. Unplug the MAF and give it some beans, it will default to a base map in the ECU for airflow and rule out the air filter and MAF if the issue is still there. My money is on plug gaps or wiring to the sparks.
#9 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 19 August 2014 - 12:00 PM
Mine did a similar thing that turned out to be nothing more than the coil pack plug was not fully clicked home.
#10 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 19 August 2014 - 04:54 PM
I've checked the coil pack connection and it's fine.
What plugs would you recommend for a (effectively) Stage 3 VXT?
#11 Ormes
Ormes
  • 4,612 posts
Posted 19 August 2014 - 05:08 PM
I *believe* ngk iridium 7s but depends on state of tune. I use 6s on a stage 2.
Edited by Ormes, 19 August 2014 - 05:09 PM.
#12 redvts
redvts
  • 1,472 posts
Posted 19 August 2014 - 05:10 PM
Mines stage 3 and it has iridium BKR6IEX plugs in it
#13 redvts
redvts
  • 1,472 posts
Posted 19 August 2014 - 05:11 PM
'7s' gave a flat spot in mine
#14 Parrappa
Parrappa
  • 68 posts
Posted 20 August 2014 - 07:50 AM
Probably not the same problem, but I had an issue where the engine would violently cut out going up the rev range in 1st and 2nd gears. Changed out the MAF, coil pack, plugs, had all the wiring checked and it ended up being the ECU, there was a couple of faults on it.
Really wish I had just sent my ECU away initially as it all became quite costly, hindsight is a wonderful thing....
#15 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 24 August 2014 - 12:52 PM
Woohoo, fixed!
Got some plugs as recommended by redvts (NGK Spark Plug Iridium BKR6EIX 6418) and it seems to have done the trick!
For any searchers, I had the OEM Bosch ones in
#16 Ormes
Ormes
  • 4,612 posts
Posted 24 August 2014 - 01:24 PM
thumbsup
#17 redvts
redvts
  • 1,472 posts
Posted 24 August 2014 - 03:48 PM
I win :P
#18 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 15 September 2014 - 07:21 PM
Not so fast - it's doing it again. Looks like a boost problem at 3.5-4k revs
I've lost patience with it so it'll be going somewhere to get it fixed (not Vauxhall or any other local garage or even Lotus Newcastle) which will more than likely be MMG as long as I can get it down there and I have enough £s.
Anyone wanting to mod their turbo past a stage 1.5 - don't bother. A remap and a pre-cat are sufficient. Worst thing I've done is get that fcuking VXR turbo fitted
#19 Tibbles Stryker
Tibbles Stryker
  • 1,941 posts
Posted 15 September 2014 - 07:59 PM
Well that's put me off, stage 2 seems enough anyway 😍
#20 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 16 September 2014 - 12:48 PM
Ha I meant don't bother going from a stage 2 upwards!
