Misfire Problem - Stage 2 Turbo With Vxr Turbo
71 replies to this topic
#21 Detta
Detta
  • 417 posts
Posted 16 September 2014 - 03:37 PM
Plenty of people go beyond S2 without any problems! This seems to be a bit of a confusing one though, please keep us posted and best of luck getting to the bottom of it.  :huh:
#22 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 16 September 2014 - 09:35 PM
Update Took it out tonight and it only has this problem in 3rd gear under hard acceleration. It also reaks of petrol and is running quite rich as at times the exhaust backfires when I'm doing an emergency start
#23 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 17 September 2014 - 11:36 PM
Map ignition table checked? Missing under load? Mine did this a while, was 2nd faulty coil pack.
#24 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 18 September 2014 - 06:28 AM
Excuse my ignorance but how do I check this? I think it is something spark related as as soon as I change the plugs the problem goes, then returns.
It's on its third coil pack now, and the last one I took off wasn't faulty and neither is this one
#25 siztenboots
Posted 18 September 2014 - 07:29 AM
its not the map , but you could pull fuse 8 and reset it incase the lambda is reading air leak. how old is the fuel in there, is it ul or super? how old are the plugs and what is the gap (set at 0.7mm) and electrode condition , is there signs of water/rust around the crush washer. its usually at the point of highest load that fuel/ignition highlights any point of weakness.
#26 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 18 September 2014 - 02:05 PM
No error codes
Runs on super UL
Plugs are 200 miles old and they were perfect. Still are.
Seems a strange (and annoying) one like :(
#27 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 19 April 2015 - 07:40 AM
UPDATE:
I took the car to MMG where a remap was done and that seemed to remedy it.
Now it's started again; I've changed the plugs (NGK iridium .7 gapped) and fitted an OEM coil pack and the problem still persists so I know that the plugs and coil pack which were removed are perfectly fine.
It occurs under hard acceleration at about 2,800 revs in third gear. It misfires and the turbo flutters like a motherfucker.
The thing is, it doesn't happen every time.
#28 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 19 April 2015 - 08:32 AM
UPDATE:
P4cks!!
IVe just had these symptoms on mine, turned out to be the start of a failing MAP SENSOR (the sensor on top of the intercooler or chargecooler 0- whatever fitted)
Borrow one from a local VX like I did to confirm the problem.
Let me know how you get on
Mark
#29 SteveA
SteveA
  • 9,157 posts
Posted 19 April 2015 - 02:59 PM
Give the boost solenoids a test to make sure they are functioning as they should.
#30 stu8v
stu8v
  • 745 posts
Posted 19 April 2015 - 04:59 PM
You sure it's not over-boosting
#31 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 20 April 2015 - 10:18 AM
cheers mbes - i've just ordered a new MAP sensor so here's hoping it's that!
Will report back
#32 Judderman
Judderman
  • 869 posts
  • Interests:Shooting, Driving on Welsh Roads, Gaming Xbox/PC
Posted 20 April 2015 - 10:25 AM
I had a simular issue last year, may items changes to locate the issue and it resulted in the Boost Control Solenoid was buggered giving me symptoms you describe. Was only £23 from Courtenay Sport Ltd and a simple swap for people with small hands
#33 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 20 April 2015 - 10:28 AM
Aye it's had a new one of those fitted already so it's not that.
#34 FLD
Posted 20 April 2015 - 10:39 AM
Does OP_COM give live sensor readings on a turbo?  Might be a good way of monitoring a sensor to see if its faulty.
#35 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 20 April 2015 - 10:52 AM
Ah I'm not sure actually. I've got an OP-COM so if after fitting the new MAP sensor it's still fcuked then I'll give that a go. Do you know what the readings should be so that I know what I'm looking for?
#36 stu8v
stu8v
  • 745 posts
Posted 20 April 2015 - 11:18 AM
What boost level are you running at?
#37 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 20 April 2015 - 11:24 AM
I have no idea
#38 Detta
Detta
  • 417 posts
Posted 20 April 2015 - 11:34 AM
How much was the MAP sensor P4cks? Do you have a part number and place of order? I've been doing a bit of a spring clean/refresh given the age of the car, are they as costly as the MAF?
#39 siztenboots
Posted 20 April 2015 - 12:41 PM
93170309
#40 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 20 April 2015 - 01:40 PM
£48.94 from carparts4less
