if youve not checked, the earthing on the ECU and chassis?
#81
Posted 27 November 2014 - 03:58 PM
#82
Posted 28 November 2014 - 08:50 AM
You raise an interesting point, there is the eye connector which fastens to the ECU mounting bolt, I have checked the ECU and when this is connected the ECU is earthed. Once the ECU is earthed then this should be correct?
Thanks
#83
Posted 28 November 2014 - 09:47 AM
Thats correct, that would earth the ECU to the chassis, however for the circuit to complete, the chassis needs to be earthed back to the battery.
There are two chassis earthing points front and back. The front one is underneath the n/s chassis member beside the battery. You have to have the battery out to access it.
Also do check the earthing cable to the battery, after a recent exhaustive check for starting problems and flickering display, I found out the two little screws (not blots) on the earth side of the battery had worked loose!
Joe
#84
Posted 28 November 2014 - 10:55 AM
Hi thanks for that you mention the other Back earthing to the chassis, where is that so that I have done a complete check
Thanks
#86
Posted 28 November 2014 - 01:52 PM
Thank you.
So I have now realised that I have wasted £180 on a rebuilt ECU as there is still no throttle response and I dont have my Op Com device as I sent it back due to being rubbish.
As things stand the ECU replacement has done nothing to correct the Pedal position sensor. So if I have continunity from the pedal to the ECU pins and also to the TB what else do I need to do ?????
I am now approaching thoughts of breaking it for spares as I think it would be more valuable
#87
Posted 28 November 2014 - 02:21 PM
There's a vx220 wiring loom on ebay at the moment?
please check earthing at the engine also
Joe
#88
Posted 28 November 2014 - 03:58 PM
Who rebuilt the ECU? If it had water ingress I am surprised it could be salvaged.Thank you. So I have now realised that I have wasted £180 on a rebuilt ECU as there is still no throttle response and I dont have my Op Com device as I sent it back due to being rubbish. As things stand the ECU replacement has done nothing to correct the Pedal position sensor. So if I have continunity from the pedal to the ECU pins and also to the TB what else do I need to do ????? I am now approaching thoughts of breaking it for spares as I think it would be more valuable
#89
Posted 28 November 2014 - 04:05 PM
Bluehawk Electronics.
#90
Posted 28 November 2014 - 04:06 PM
I wonder if a fault could have just damaged the new ecu in the same manner as the previous one, ie. output driver
#91
Posted 28 November 2014 - 05:19 PM
I hope not !!!!!!!!!!!!!!
#92
Posted 29 November 2014 - 11:13 AM
#94
Posted 29 November 2014 - 05:27 PM
#95
Posted 29 November 2014 - 05:38 PM
Thank you.
Why was your op-com rubbish? They are cheap and the software is a bit of a pain to install but they generally work OK. You will find it invaluable for problems like this.
#96
Posted 30 November 2014 - 01:21 PM
Hi The Op Com was reading the faults but not telling me what the fault code is. Chap who lent me his OP Com for half an hour showed throttle pedal sensor position and variable voltage from the pedal. I could not get that with mine. So I have ordered a new one
I have performed a beep test from the pedal to the ECU and also from the ECU to the Throttle body, I have checked the pedal voltage and I am getting two 5 volt readings these alter as you depress the accelerator
Unfortunately this is the limit of my circuit testing ability, I never did pay that much attention in the physics lessons.
#97
Posted 30 November 2014 - 02:03 PM
#98
Posted 30 November 2014 - 02:24 PM
#99
Posted 30 November 2014 - 05:00 PM
Edited by TheHood, 30 November 2014 - 05:01 PM.
#100
Posted 30 November 2014 - 05:05 PM
Edited by CHILL Gone DUTCH, 30 November 2014 - 05:07 PM.
Bing (1)
