Thanks everyone for your replies
Battery looks new ish and on test at rest is about 11 volts and when the car is idling just below 12v The car turns and fires no problem. All electrics apart from the pedal work perfectly
I have not checked to see that the wires were shorted to earth or battery many thanks both for the information, I will go back and test.
One thing I would like to know is the tool that is used to remove the terminals from the connectors I really would like to remove and test and replace the TB connectors terminal the Throttle Sensor block and all of the terminals from the ECU connectors. Can you recommend the tool for this, I understand that the terminals can be removed but how is this done (assuming I have the right tool)
The ECU was programmed by the guys who did the makeover with the Registration and VIN number for the car which was on the original but broken ECU and they provided me with new transponders and an ignition barrel receiver which worked a treat. Other than cleaning the ECU connectors all I have done is re-install the ECU and ensured that the connectors fit nicely and that the ECU is grounded correctly. I then started the car and still had the throttle issue, I have not re-flashed the ECU as I don;t have anything to do this with. My assumption was that the ECU had the faults removed as this was the conversation that I had with the Bluehawk guys they said that they would test the unit and repair any faults. I have removed fuse 8 and waited for about 30 mins before starting the car and retrying the throttle so that the ECU is reset.
One thing that I have not said previously is that when I picked the car up it was clear that the car had been left in the rain that day or the previous evening as the seat on the drivers side was wet when I opened the door and later when I got home I noticed that the carpets where wet also so I put them in the airing cupboard to dry but did not think anything of it until I have read a couple of the posts. As noted by the ECU repair specialists they said that the ECU had significant water damage to it, which I took to read the pins on the ECU connector had some corrosion/water damage on them. Whilst I have soaked the ECU connectors with contact solution and left them to dry again the reason why I want to check them out is to rule out any corrosion on the ECU plugs.
In addition the front and rear light clusters also had a great deal of condensation in them and these whilst the car has been in the garage have dried out and now look fantastic, but it is true to say that the car prior to pick up was not left in the dry...
The thing that continues to trouble me is that on the first occasion I looked at the car the day after it broke down on the way hone I unplugged the TB and Pedal Sensor removed fuse 8 and left it for half an hour and it started and throttle response was back, I turned off the ignition and since then I have had no throttle. Although I have removed the throttle pedal and replaced with a spare and the ECU connectors and the TB connectors and have changed the TB. I have read on a number of other threads not Vauxhall that the TPS might need to be re-calibrated is this correct, judging by the amount of components I have no changed I would not be surprised if there is no something fundamental and stupid that I am overlooking
I am pleased to tell you that I have removed both of the headlamp clusters today and cleaned and replaced the headlamp bulbs, which all work really nicely, so it does prove that some things on the car work and some of my mechanical skills still work. The next things whilst playing with the electrics, will be to remove the seats and have the bolsters repaired which will set the interior off even though it continues to frustrate every day.........................
