Fitting A Z28Net
#81
Posted 06 March 2016 - 11:40 AM
#82
Posted 06 March 2016 - 12:26 PM
Keep an eye on this one
Whats the weight difference vs. Z22SE?
#83
Posted 06 March 2016 - 12:28 PM
#84
Posted 06 March 2016 - 03:55 PM
Will watch with interest
#85
Posted 06 March 2016 - 07:05 PM
#86
Posted 06 March 2016 - 07:15 PM
I'm hoping it will fit when the engine gets here ill make some very basic measurements of the engine and then of the z22 and see if any modification will be required to the boot etc. I'm not bothered if i do need to modify it will just be good to know.
another issue I've come up with is flywheels. the v6 has a 8 bolt flywheel where as the z22 uses a 6 bolt. will i be able to use either a lightweight z28net flywheel (6.7kgs over the DM 12.4kgs) with the f23? I'm going to get an adaptor plate made up i think to get the f23 to fit if it doesn't bolt on.
I'm getting impatient waiting for the engine so can't do any checks! just firing things out there. My hope will be:
1. engine fits!
2. can get the f23 fitted so i can keep all drive shafts gear shift mechanisms etc.
#87
Posted 06 March 2016 - 07:32 PM
this is a saab auto, missing the 6 bolts holes , same block
#88
Posted 06 March 2016 - 07:36 PM
Cheers mate. Been looking at pics of the z28 flywheels and they look huge!c20let used a 8 bolt flywheel , but also can use f23 this is a saab one , same block
#89
Posted 07 March 2016 - 09:54 AM
1. engine fits!
1. Engine should fit ok - seen pics of a very similar block in an Elise.
2. The F23 will NOT bolt up. You will need some form of adaptor plate and suitable flywheel.
You could get someone like TTV to create some form of hybrid lightweight flywheel if they have designs on both the F23 compatible unit and one from a Vectra VXR unit..
#90
Posted 07 March 2016 - 09:58 AM
#91
Posted 07 March 2016 - 10:16 AM
Not sure on adaptor plate requirements, but minimum 10mm thickness will be required..
Have a look below for the guy putting essentially the same engine (GM HFV6 in NA) in an Elise.
http://www.lotustalk...-2x-fun-102052/
#92
Posted 11 March 2016 - 07:38 AM
Cheers Rossco I'll have a look at that. I was thinking 10mm will probably be required.Not sure on adaptor plate requirements, but minimum 10mm thickness will be required.. Have a look below for the guy putting essentially the same engine (GM HFV6 in NA) in an Elise. http://www.lotustalk...-2x-fun-102052/
#93
Posted 11 March 2016 - 08:14 AM
Interesting option you're thinking of.
what kind of power can one of these be easily/cheaply increased to? Or are you doing it more for the enjoyment and challenge of the engine swap rather than ultimate performance?
#94
Posted 11 March 2016 - 08:21 AM
Power wise I know the z28net can be taken up to 400 before internals need doing. But just a remap will take them from the 255/280 to around 300. I've got the A28net from the insignia so standard it 325 which with a remap will see around 340. But with the build it'll end up having a rebuilt turbo with bigger compressor and a 3" exhaust so hope to get around 400 which in the insignia 400bhp the engine produces around 406lbft of torque. That's going to be the biggest issue reigning in the torque. But not chasing the figures as much just want to be the first to shoe horn the engine in the backInteresting option you're thinking of. what kind of power can one of these be easily/cheaply increased to? Or are you doing it more for the enjoyment and challenge of the engine swap rather than ultimate performance?
#95
Posted 11 March 2016 - 08:25 AM
Excellent sounds like as good an excuse as any!
I'll be watching with interest.
#96
#97
Posted 11 March 2016 - 10:45 AM
Audacious plan!
You are right to think that 400 ft/lb of torque is quite a lot for a VX. When I took you out last year we only used 340 ft/lb.
Edited by Nev, 11 March 2016 - 10:46 AM.
#98
Posted 11 March 2016 - 01:32 PM
Yup it should be fun! Might be able to give you a run for your money Nev!!Audacious plan! You are right to think that 400 ft/lb of torque is quite a lot for a VX. When I took you out last year we only used 340 ft/lb.
#99
Posted 11 March 2016 - 02:56 PM
That would be nice however I might be tempted to flick my little switch !
#100
Posted 22 March 2016 - 09:26 AM
