:thumbs up:Love v6 ;-)All my old bodywork has gone on to Arctic Monkeys car! Yh but Nipper doesn't have a V6 soundtrackI was serious
Sell me all of your old bodywork then
700hp lol
having been in Nipper that is well enough
Fitting A Z28Net
#141
Posted 21 April 2017 - 06:24 AM
#142
Posted 21 April 2017 - 08:24 AM
Come on Mopey - We need the money shot!
#143
Posted 21 April 2017 - 09:05 AM
Not sure if the pic worked as I'm on my phone. I will be updating my project thread at some point so it will all be in there :thumbs up:
#144
Posted 21 April 2017 - 09:06 AM
#145
Posted 21 April 2017 - 09:39 AM
Great! So looks like the engine with the standard VX subframe would just be too tight a fit?
#146
Posted 21 April 2017 - 09:45 AM
#147
Posted 21 April 2017 - 11:13 AM
Interesting!
Much kudos for attempting this!
The rear of the V6 Exige is quite differen though as far as the suspension and uprights and hubs goes compared to the VX and 4-cylinder Elises...
V6:
4-cyl:
Also, the V6 rear hubs are from Toyota and are a 5x114.3 PCD (yes, the V6 exige runs 2 different PCD's.. 5x110 front, 5x114.3 rear), also I don't know if these hubs will work with the existing VX ABS system. They may have the hall-effect sensors for a BOSCH ABS system that's used in Elises after 2010 or so, instead of the inductive pickups in the VX220 hubs that are sourced from early-2000 vauxhalls and were used up to that time.
Perhaps Toyota has some older inductive style ones that might work, but it will likely need to send the same pulses/revolution as the front hubs or the ABS unit will go nuts.
Or will you be trying to graft the VX hub back onto the V6 Exige uprights or also go to the V6 Exige BOSCH ABS system?
#148
Posted 21 April 2017 - 11:39 AM
I did look into this a while ago when I got an offer for a German V6 subframe, but the other needed parts for it like the wishbones and hub carriers made it all quite expensive. And then I discovered the weight of a V6 subframe...
But will follow this build closely!
(I'm still thinking about a longer wheelbase VX, but them with a spaced out rear frame like you did there. )
Edited by Exmantaa, 21 April 2017 - 11:41 AM.
#149
Posted 21 April 2017 - 12:25 PM
You just need to spend £10-12K..
https://lotusproacti...rame-prototype/
#150
Posted 21 April 2017 - 01:01 PM
I'm having custom wishbones made to keep the VX hubs so it's not got different PCD front and rearInteresting!
V6: 4-cyl: Also, the V6 rear hubs are from Toyota and are a 5x114.3 PCD (yes, the V6 exige runs 2 different PCD's.. 5x110 front, 5x114.3 rear), also I don't know if these hubs will work with the existing VX ABS system. They may have the hall-effect sensors for a BOSCH ABS system that's used in Elises after 2010 or so, instead of the inductive pickups in the VX220 hubs that are sourced from early-2000 vauxhalls and were used up to that time. Perhaps Toyota has some older inductive style ones that might work, but it will likely need to send the same pulses/revolution as the front hubs or the ABS unit will go nuts. Or will you be trying to graft the VX hub back onto the V6 Exige uprights or also go to the V6 Exige BOSCH ABS system?
#151
Posted 21 April 2017 - 01:02 PM
shame , the new v6 wishbones are one the better bits lotus did
#152
Posted 21 April 2017 - 01:15 PM
Maybe but then they're still cast aluminium and not T45 tubular like mine will be. And the wishbones aren't costing me a lot as all I'm paying for is material and my friend (aircraft welder and fabricator) is making them for me.shame , the new v6 wishbones are one the better bits lotus did
#153
Posted 21 April 2017 - 01:16 PM
#154
Posted 21 April 2017 - 01:45 PM
Edited by Rosssco, 21 April 2017 - 01:46 PM.
#155
Posted 21 April 2017 - 02:05 PM
#156
Posted 21 April 2017 - 05:09 PM
I think he was referring to me
Details!!!Oh I'm just building a baby venom in spare time � love stuff like this
could be wrong though
Both!
#157
Posted 21 April 2017 - 05:23 PM
#158
Posted 21 April 2017 - 06:51 PM
Is the exige sub frame a straight bolt on?
#159
Posted 21 April 2017 - 06:52 PM
Bing (1)
